3rd Generation GK Specific Suspension & Brakes Sub-Forum Threads discussing suspension and brake related modifications for the 3rd generation Honda Fit (GK)
Stainless Steel Brake Lines
Old 07-07-2015, 02:32 PM
Throwin_FitS's Avatar
Question Stainless Steel Brake Lines
Hi guys,
I tried searching on and off the forum and couldn't find this answer. Does anyone here have any information on SS Lines for the GK? I'm not a fan of the brake performance and wanted to stiffen the feel and change pads while I'm down there.
OR does anyone know if the GE lines will work?
THANKS!!
Old 07-08-2015, 08:11 PM
wonton2049's Avatar
+1
I'd like to know as well about the lines.
Old 07-22-2015, 10:45 PM
sabawballs's Avatar
on my next service i'll try to install my old goodridge ss brake lines from my GE to the GK and will see if it is compatible
Old 07-23-2015, 11:10 AM
You are awesome! Thanks please let us know!
Old 07-23-2015, 12:33 PM
gkitf16's Avatar
I installed Good ridge SS lines on my '09 about 1.5 yes ago, quality parts with all the clips and hardware. They do tighten up the pedal a bit. Best tip when bleeding the front calipers, rap on them with a wood block to burp off small bubbles, won't get all the air unless you do. Snug up the clearance on the rear shoes until you've got a light drag and only a few clicks on the handbrake and you're all set. Nice & tight pedal now!
Old 06-17-2017, 10:13 AM
TougeMonster_GK5's Avatar
So does GE SS brake lines work on our GKs?
Jagged1
11-28-2017 03:33 PM
samcl9
11-24-2015 07:52 PM
ex-GD3
08-26-2015 10:03 AM
Ein
11-30-2008 02:44 PM
rodpaine
04-07-2008 03:54 AM
Quick Reply: Stainless Steel Brake Lines
