3rd Generation GK Specific Suspension & Brakes Sub-Forum Threads discussing suspension and brake related modifications for the 3rd generation Honda Fit (GK)
Wilwood on GK5
Old 01-15-2019, 11:05 AM
Kevin Lam's Avatar
Dynapro Radial Big Brake Front Brake Kit (Race) comes with high-temperature pad (BP30) and Spec-37 Iron rotor. I am wondering if standard pad (BP10) could be used together with this spec-37 iron rotor. Do you have any idea?
Old 01-15-2019, 11:44 AM
evilchargerfan's Avatar
click on your own link, click on the " Brake Pad Plate: " link .... and there will be a list of avail pads that work for that setup
Old 02-10-2019, 07:48 AM
bjosuesr's Avatar
Evil what made you choose the four piston over the six? Also are you noticing any bedding issues using the bp20 or bp30 pads over the bp10 due to the higher temps needed to bed them in? They look great on your vehicle and yes I agreee they are brake dust city.
Old 02-10-2019, 07:53 AM
bjosuesr's Avatar
Thanks for your post. Do you use any spacer? My rims probably interference with the calipers. Just wondering if willwood could offer other Hat with differenceHat Offset Dimension (in):0.45
Kevin no I don’t use any spacer. My wheel offset is 0.38 they clear fine in the 16in size wheel. Sorry for the length of time between my posts.
Old 02-11-2019, 06:02 PM
-I am too poor for 6
-there have been reports of SOME wheels (15 inch) that do not clear 6, even though Wilwood says 15s should clear, some simply do not clear
-no bedding issues, I just drove it hard as heck and got temps up as much as I could w/o endangering myself/my surroundings
-ty for the kind words
Old 02-16-2019, 08:22 AM
bill bosco's Avatar
how are the race shoes different from stock ?
Old 02-16-2019, 08:30 AM
bjosuesr's Avatar
The only thing I know of is the compound used has a more aggressive bite for the race pads and the temp needed for the correct use is higher
Old 04-24-2019, 11:01 AM
bertosfit's Avatar
you inspired me!
Old 04-24-2019, 11:55 AM
bjosuesr's Avatar
They look great
Originally Posted by bertosfit
you inspired me!
Old 05-12-2019, 06:26 PM
CodemanGK5's Avatar
A worthy upgrade! Excited to not have to watch the stock calipers get rusty.
Old 05-13-2019, 07:28 AM
2Rismo2's Avatar
Which Konigs are those? Looks great against the blue!
  #32
Old 05-13-2019, 04:03 PM
codeman, you gonna join us .... and find a way to get some wilwood rear disk brakes ....
  #33
Old 05-14-2019, 07:53 AM
CodemanGK5's Avatar
Thanks! Konig Lightning 16x7
Man, I've already given up lol. Kit is way overpriced, HRV rear beam is too different to swap components. Only thing I've been thinking is maybe the spoon rear adjusting plates that give you a mounting bracket and piecing it togeher from there.
  #34
Old 05-14-2019, 08:21 AM
JingJangJoe's Avatar
Hi,
What's the size of the tyres? Thanks
  #35
Old 05-14-2019, 08:24 AM
CodemanGK5's Avatar
Originally Posted by JingJangJoe
Hi,
Right now I'm running 195/50 16 with no rubbing issues, soon to upgrade to 205's
  #36
Old 05-14-2019, 11:12 AM
Nice..... thanks for the info!!
  #37
Old 04-04-2020, 11:49 AM
Sulayman Ahmed's Avatar
bp20 pads = brake dust city
I've been trying to search all your threads but I can't seem to find it... what size rotors are you running? The only 4 piston Wilwood kit I can find is the one on Axion's GK5 page, with the 11.6" rotors.
Is it that one?
  #38
Old 04-06-2020, 12:39 PM
Is it that one?
I am using 160-12838-BK
(10.32)
a quick google search will reveal 1 seller that has it for $64.99
  #39
Old 04-06-2020, 12:41 PM
looks like sulayman has discovered that fast brakes has a kit, so one can add rear disc brakes. if I am reading this "kit" correctly, you can choose your own caliper .... which should in theory include wilwoods ....
https://www.fastbrakes.com/ProductDe...r-11-disc-swap
  #40
Old 02-22-2021, 09:46 AM
Z062FIT's Avatar
Wilwood 6 piston setup
Just purchased the 6 piston calipers. Does anybody know if I need new stainless brake lines? Cheers!
Quick Reply: Wilwood on GK5
