3rd Generation GK Specific Suspension & Brakes Sub-Forum Threads discussing suspension and brake related modifications for the 3rd generation Honda Fit (GK)
Wilwood on GK5
Old Feb 22, 2021 | 10:02 AM
  #41
CodemanGK5's Avatar
Originally Posted by Z062FIT
Just purchased the 6 piston calipers. Does anybody know if I need new stainless brake lines? Cheers!
yes, the wilwood kits say to use braided stainless lines. Gonna want that little extra pressure for the 6 pot for sure!
Old Feb 22, 2021 | 10:07 AM
  #42
Z062FIT's Avatar
Stainless lines
Yeah, I already have stainless lines. Wondering if I need "new" ss lines for a different caliper. Please respond if you have installed the 6 piston calipers and know if they need updated... thank you codeman!
Old Feb 22, 2021 | 10:15 AM
  #43
CodemanGK5's Avatar
i have the 4 pot kit on mine with the stainless lines i had previously installed, no problems with length or fitment, if the lines are still in good shape you should be fine unless the 6 pot caliper is that much different that it needs a longer line or different fittings.
Old Feb 24, 2021 | 08:18 PM
  #44
USDM's Avatar
Originally Posted by Sulayman Ahmed
I've been trying to search all your threads but I can't seem to find it... what size rotors are you running? The only 4 piston Wilwood kit I can find is the one on Axion's GK5 page, with the 11.6" rotors.
Is it that one?
The DPHA calipers utilize the factory-sized rotor.
Old Feb 24, 2021 | 08:52 PM
  #45
Z062FIT's Avatar
6 pot brake line
I thought there is a banjo bolt at the caliper but I could be crazy...
Old Feb 25, 2021 | 09:03 AM
  #46
CodemanGK5's Avatar
it does, my kit came with new ones so im not sure if they are the same size as the stock caliper banjo
Old Apr 7, 2022 | 12:45 PM
  #47
evan.'s Avatar
I’m running 16x7+45 Enkei EDR9’s on my Fit. I was considering upgrading my front calipers but am not sure if the 6 pot will fit a +45 offset. Any thoughts?
Old Apr 7, 2022 | 01:07 PM
  #48
Z062FIT's Avatar
6 pot on 16s.
I finally got them in my hand and they nearly fit my 15x8 +28 Konig hypergrams, they were just shy. All this to say I think your 16s will be fine.
Old Apr 21, 2022 | 03:30 PM
  #49
Trauma714's Avatar
Wheels?
Anyone know where to get these wheels? Searched google for type-r knockoff/replicas and even with an image search can't seem to find anything in 16" let alone 4x100.
Originally Posted by bjosuesr
Old Feb 1, 2023 | 12:33 AM
  #50
bcdesignco's Avatar
Does anyone know if the willwood calipers for the stock 10.2" rotors will clear the stock GE8 16" sport wheels? The diagram show a the caliper sticking out from the rotor where it meets with the wheel .840 I tried to measure the clearance on my wheels, but it's hard to say. I came up with what looks like 3/4"
Old Feb 1, 2023 | 11:48 PM
  #51
bcdesignco's Avatar
My willwood brake kit showed up today. I'm still waiting on my stainless brake lines, but I figured I check and see if the stock 16" wheels clear the calipers. I attached the calipers to the mount and to my amazement there is 1/8" clearance between the wheel and the new calipers!
Linksy
Oct 30, 2023 01:21 AM
1stVR6
35
Jan 14, 2023 09:48 AM
PJ Villaflor
May 12, 2020 04:26 PM
PHNTMONE
Feb 18, 2015 01:43 PM
Jelani
Jan 8, 2015 08:26 AM
