3rd Generation GK Specific Suspension & Brakes Sub-Forum Threads discussing suspension and brake related modifications for the 3rd generation Honda Fit (GK)
tanabe strut tower brace
Old 11-28-2018, 07:33 PM
bill bosco's Avatar
was reading some posts on the tanabe tower brace from a while back . the last post mentioned that it appeared that the mounting plate now blocked
access to the fuse box cover , can anyone verify this ?.if that's the case , it does'nt sound like a very practical mod
Old 12-02-2018, 02:46 PM
Yup. It does block the fuse cover. Takes me a few minutes to remove that side of the brace to access the fuses.
Old 12-02-2018, 04:14 PM
bill bosco's Avatar
thanks for the heads -up , looking at the pictures i still can't figure out what it's attached to . so far , i've got 2 subframe braces under the front and
2 braces in the back ( one across the bottom in front of the beam axle and the other across the rear upper seatbelt mounts ) they work wonders
for the feel of the car
Old 12-06-2018, 03:44 AM
USDM's Avatar
Save your money and spend it on a Progress rear anti-sway bar instead of the Tanabe strut bar. It's a much better, and effective, mod.
Old 12-06-2018, 08:03 PM
bill bosco's Avatar
yes , i have one , was my first mod
Old 12-07-2018, 03:22 PM
evilchargerfan's Avatar
so that said, front sway bar next?
Old 12-08-2018, 09:18 AM
i would pass on the rear sway bar (makes your car drive like 2 separate pieces) and start with the front sway bar on the Fits. the car leans too much and loses posture while turning. then get a LSD.
Old 12-08-2018, 08:01 PM
bill bosco's Avatar
i have a blox swaybar for the front ,but haven't put it in in yet , pretty much looks like i have to drop the subframe to get it in so right now it's winter and i'm not in a rush .
it probably would make a big difference i'm sure .and no , the car doesn't loose it's posture while turning , it's rather composed , i'd say . the braces on the car do alot for
roll stiffness
Old 01-15-2019, 03:30 PM
USDM's Avatar
It's an FF car. If you want to make it rotate "better," you'll want to stiffen up the rear end.
Old 01-15-2019, 04:27 PM
roll stiffness
pics of that front "sway bar" please?
Old 01-30-2019, 05:00 PM
Mee Boc's Avatar
Definitely this. Even with traction control off, it's tough to get to slide around tight corners.
Old 01-30-2019, 05:15 PM
sttill waiting for pics of that front sway bar ....
Old 10-11-2019, 07:25 PM
bill bosco's Avatar
been looking at the various pictures of the tanabe tower brace , so , you really do have to undo the mounting bracket to access the fusebox ?
Old 10-12-2019, 03:01 AM
Absolutely.
Old 10-12-2019, 03:24 PM
TougeMonster_GK5's Avatar
just re-installed mine last night after getting the car back from the shop. If you can see on the driver side, the bracket is blocking entry to the fuse box. Not a big deal to remove if need be! So go buy it! 😎
Old 02-05-2021, 05:55 PM
blanka98's Avatar
Bringing this back from the dead.....just bought one and just figured out that this bar mounts to the thin sheet metal.....I'm quite disappointed at Tanabe. This will provide only looks over anything....
Old 02-07-2021, 03:31 AM
JingJangJoe's Avatar
that's right. The front strut bar does nothing practical at all.
Old 02-07-2021, 09:56 PM
NWCH's Avatar
I like mine.
Old 02-07-2021, 09:57 PM
NWCH's Avatar
There is a matching lower front brace also. It's on my future purchase list.
https://www.ebay.com/itm/TANABE-SUST...53.m1438.l2649
Old 02-07-2021, 10:03 PM
NWCH's Avatar
What it looks like installed.
Jz1219
09-10-2012 11:29 PM
jt.wilson89
06-24-2009 12:06 AM
Will I Am fit.
SoCal Classifieds
14
02-12-2009 09:43 PM
fit4kris
Tanabe Racing Development USA
17
10-16-2007 12:19 AM
fit4kris
04-14-2007 04:00 PM
Quick Reply: tanabe strut tower brace
