Advice on choosing LV CVT tires/wheels for long distance interstate, comfort
Old Oct 18, 2014 | 05:37 AM
Namae Kana's Avatar
I bought my 2015 LX CVT to drive long distances. Typically 400 miles, sometimes 125, often 2500. I average 25-35,000 miles per year.
The LX CVT came standard with: Firestone FR740 185-60R15 84T treadwear 400 traction A tires, and (I believe) 15x5-1/2J wheels.
Which tires would you recommend I purchase to soften the road for long distances? Should I get larger and/or wider wheels?
Old Oct 18, 2014 | 10:58 AM
kenji815's Avatar
the stock wheels are pretty comfortable already why would you want to change it already when it's brand new?
large and wider wheel may have problem mounting on stock 5.5" wheels.
just stick with OEM size.. 60 profile tire should give plenty of comfort.
Old Oct 19, 2014 | 02:43 AM
Namae Kana's Avatar
Would a fatter tire than the stock 185-60R15 have any advantages?
Old Oct 19, 2014 | 09:21 PM
kenji815's Avatar
No becuase it would be too fat for the narrow stock rims the most likely the tire ratio wouldbe incorrect when you go wider to 195 for example.
You would end up with poor performance. Best thing would be go for low resistance tire.
Old Jan 16, 2015 | 03:06 PM
DaBinChe's Avatar
stock steel wheels are 15x6 not 5.5", a 6" wide rim can fit up to a 205 wide tire. To keep the diameter close to stock you'll have to have a smaller aspect ratio as you go wider.
I just replaced my the wheels/tires and boy the new ones ride sooo much quieter.
Old Jan 22, 2015 | 02:57 PM
Padawan's Avatar
If ride comfort is your primary goal, you can move to a 14" wheel and 185/70R-14 tires.
Old Jan 22, 2015 | 04:04 PM
Wanderer.'s Avatar
The GK steelies are 6"?
That's cool. GE are 5.5. Guess i'll look out for GK throwaways.
Old Jan 23, 2015 | 12:29 PM
Fit Charlie's Avatar
Taller sidewall = cushier ride.
Maybe someone can chime in on how much bigger you can safely go, or you might want to go to a smaller rim to allow more sidewall without increasing your outer diameter.
Old Jan 23, 2015 | 09:35 PM
DaBinChe's Avatar
I'm using 195/60-15 and it is much smoother and quieter ride. It is about 1/2" larger in diameter.
I also think that the stock 15x6 is a little wide for a 185. 6" wide rim is perfect for a 195 or a 205.
Theoretical diameter:
stock steel 15x6 185/60-15 = 603mm
stock aluminum 16x6 185/55-16 = 609.9mm
I'm using 195/60-15=615mm
slinginit
Aug 30, 2017 08:29 AM
Dean
Mar 24, 2015 11:38 PM
Myxalplyx
Aug 27, 2014 11:07 AM
ds61761
Feb 14, 2012 10:37 AM
Enzo Wagon
Apr 27, 2008 08:59 AM
