what tire pressure are you running?
Old Jan 8, 2015 | 11:46 AM
SteveSatch's Avatar
Old Jan 8, 2015 | 12:21 PM
Rampo's Avatar
Lot's of threads and opinions already out on this subject. These should help:
https://www.fitfreak.net/forums/fit-...questions.html
https://www.fitfreak.net/forums/2nd-...-pressure.html
Old Jan 8, 2015 | 01:47 PM
Chazman's Avatar
Selling dealer filled up to 35 psi during their PDI when I bought the car (checked as soon as I got home) and so far so good.
Old Jan 8, 2015 | 02:22 PM
Zute's Avatar
I found my tires were down to 25psi or slightly less just recently! I'm not sure if it is just the cold weather here in San Diego, or if they were always underinflated. Anyway, the door sticker said 32psi (I think), so I went with that.
Old Jan 8, 2015 | 05:09 PM
James Butler's Avatar
my tire pressure
Mine came from the dealer with all 4 at 28 PSI. I went to 36 PSI on all tires. No problems. Max on tire said 44 PSI.
James
Old Jan 9, 2015 | 10:31 PM
Jim Grames's Avatar
28 front 20 rear I don't like the choppy ride. now I can live with it.
Old Jan 10, 2015 | 10:09 AM
exl500's Avatar
Slightly above the door jam numbers - 36 all around.
I haven't owned a car in decades. I check the tires monthly, along with the oil and coolant. Is that too little, too much, or just right?
Old Jan 10, 2015 | 07:45 PM
Vanguard's Avatar
better safe than sorry
Old Jan 10, 2015 | 08:33 PM
BILLBOGEY's Avatar
James
I also inflated my tires to 36psi, seems to work fine.
Old Jan 11, 2015 | 03:01 PM
FitasaFiddle15's Avatar
Just had my first oil change/tire rotation yesterday. My tires are inflated to 32 PSI.
Old Jan 12, 2015 | 12:32 PM
GeorgeL's Avatar
Whenever I have used the factory pressures I end up wearing out the edges of the tires, and I'm not exactly a sporty driver. I tend to add 4-6PSI to the factory values to make the tires wear normally.
Old Jan 12, 2015 | 09:52 PM
Bassguitarist1985's Avatar
Mine had 25psi in each. Cold weather likely has brought them down a bit. Inflated to 35psi, see how different it drives.
Old Jan 13, 2015 | 12:42 AM
GeorgeL's Avatar
It takes about 20F temperature change to change tire pressure by 1 PSI. Cold may have something to do with it, but tires do naturally leak down with time.
Old Jan 13, 2015 | 09:40 AM
SteveSatch's Avatar
Mine had 32 from the dealer. I bumped them up to 36.
daddyscooltv
17
Nov 1, 2022 04:41 PM
James Butler
Nov 19, 2014 11:16 AM
bukowski
Nov 14, 2012 05:44 AM
agios11
Aug 24, 2012 11:41 PM
boots11234
Oct 27, 2008 03:55 PM
