Two More TPMS False Alarms - Unofficial Honda FIT Forums
Old 02-06-2019, 03:39 PM
Both my 2015 and my son's 2019 lit up their TPMS warning lights. I checked tire pressures, and they were all the same, just the way I had set them. This is like the boy who cried wolf. Should I start ignoring the TPMS warning and wind up with a flat tire? Probably not.
Old 02-06-2019, 04:00 PM
If you made sure the tires are in good condition at the correct air pressure, its just TPMS false alarm or bad sensor.
Cannot speak for the 2019.
The 2015 EX which I also have works on passive TPMS. There is no TPMS device in the whee/tires. After you got all tire/wheels installed with proper air pressure, reset TPMS with a button at bottom of the dash, above the gas door latch. I forgot the exact process. You can search online or refer to the owners manual.
Read the 2019 needs to reset with buttons on steering wheel from a recent threat about TPMS reset. You can search for that.
Old 02-06-2019, 04:19 PM
evilchargerfan's Avatar
I just press the tpms icon button to reset, and move on with my life
so far, so good, no bodily harm to myself. I'll report back if I get hurt
Old 02-06-2019, 04:30 PM
Once I dumped the oe Bridgestones, the recurrent false alarms have gone away with the Michelins.
Old 02-06-2019, 09:23 PM
fitchet's Avatar
The Honda FIt's passive TPMS system has lead me to make sure I have a good tire pressure gauge with me IN the vehicle.
I mean?
How can you really ignore it?
So for me? When it illuminates, I pull over and check.
Better safe than sorry.
Old 02-07-2019, 11:17 PM
On my 2015 Fit, the TPMS is temperature sensitive. Mostly if the temp drops suddenly this week the temp has gone from the upper 40s to the mid 70s tomorrow morning is supposed to hit the mid 20s no joke..
Old 02-08-2019, 08:13 AM
No false alerts on my 2015 thankfully
Old 02-09-2019, 12:32 AM
GAFIT's Avatar
11 years later...no false alerts from our GD Fit and they still work.
Several false alerts from our '17 Golf that also uses the indirect (aka. no actual) sensor method.
No false alerts from my '13 Lincoln that also has actual sensors.
Old 02-09-2019, 07:58 AM
I'm glad the Fit has that system. Paying $100 for more for each wheel sensor can add a lot to the price of a new set of wheels. The best system I ever had was one I added to my motorcycle. It had a display that showed the actual temperature and pressure in each tire. You can buy systems like that for cars, but the price is too high and the importance too low.
Old 02-09-2019, 07:59 AM
I think you've discovered the reason for the false alarms.
Old 02-09-2019, 08:05 AM
Definitely! Once I got a genuine TPMS warning. I was a couple of hours from home, and one tire was down a few pounds. I didn't have my pump with me, so I stopped at an auto parts store and bought one. After pumping it up, I didn't have to add air again.
By the way, a good valve cap is important. A man from a tire company gave a presentation at a motorcycle rally, and he said that the Schrader valve can sometimes be jolted by bumps in the road and not hold back the tire pressure. A good quality metal cap will keep the air in. I like the type with the little valve tool on top.
Old 02-09-2019, 08:11 AM
Right. I was the one who posted the question. Unfortunately, searching in the new, streamlined Owners Manual will not help. There is over a page of text about the TPMS, but no mention of how to reset (Calibrate) it. After posting here and searching online, I learned about the calibration procedure. Unless you know the terminology that Honda uses for the steering wheel controls, you'd never find the article.
My 2015 has the reset button to the left of the steering wheel, but I sometimes have to go through the process several times before it will reset.
Basically, the Fit's TPMS is a required, imperfect system that can warn of low pressure in one tire - or not.
Old 02-09-2019, 08:21 AM
The system sucks. I live in the snow belt. I've had it go off when my wheels were packed full of snow or because of wheel slippage? All four air pressure were within a pound of each other and within two pounds of the recommended pressure on the door.
Blackbeard
11-08-2010 12:52 PM
InternDoc
06-30-2008 10:03 PM
agent_paul
12-08-2007 12:58 PM
trowpa
Honda Fit Dealer Reviews
18
08-11-2006 03:23 PM
big Fit
06-23-2006 04:07 PM
Quick Reply: Two More TPMS False Alarms
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
