7 warning lights out of the blue [2018 FIT]
Old Jun 2, 2019 | 09:53 AM
FATFITBOY's Avatar
Question 7 warning lights out of the blue [2018 FIT]
A few nights ago I got into my 2018 fit and 7 warning lights popped up on my dash.
Here are they are
1. Hill start assist problem
2. Road departure mitigation system problem
3. Power steering system problem
4. Tire pressure monitor problem
5. Emissions system problem
6. Vehicle stability assist problem
7. Hill start assist problem
Any ideas as to what this could be causing this?
I have googled and cant find this problem anywhere else.
Any input would be greatly appreciated.
Thanks in advance
Old Jun 2, 2019 | 11:41 AM
woof's Avatar
There is probably one single problem which is triggering a cascade of warning lights but figuring out that one problem is the fun part. I'd take a look at TPMS first and manually check all the tire pressures (incl spare). Beyond that you're still under warranty so maybe let the dealership share your pain. Incidentally you have hill assist listed twice.
Old Jun 2, 2019 | 01:51 PM
Hootie's Avatar
Have the battery tested preferably at a dealership or a shop knowledgeable about these most recent batches of Honda circa 2013 to now (most parts warehouses/stores do charging system tests incorrectly due to not knowing how the GK5's charging system works), especially if you're within 3 years/36k miles.
Low voltage will cause system error codes to set.
Report back with findings if possible.
Old Jun 16, 2019 | 05:36 PM
FATFITBOY's Avatar
Sorry for my delay in replying.
I tested for codes and it was only showing one.
Misfire on cyl 3. I deleted the code and all of the false alarms went away shortly thereafter.
Old Jun 17, 2019 | 09:44 AM
evilchargerfan's Avatar
were you playing with the maf/intake?
Old Jun 28, 2019 | 11:30 AM
Hisssyfit's Avatar
I am having a similar problem with my 2018 fit! I took it to the dealer and they ended up replacing the fuel injector because there was a misfire in cylinder one and four. A few days after I got the car back all six lights came on and I brought it back to the dealer. They said they just need to reset the computer and sent me on my way but not long after that all the lights came back on. I’m bringing it back tomorrow but it seems so weird that both of our 2018 fits having the same problem around the same time!
This is my first time posting sorry if I did anything wrong.
Old Jun 28, 2019 | 12:00 PM
Mark Schofield's Avatar
same with min about 6 months ago. Cyl #2. Dealer replaced injectors and coil packs
Old Jun 28, 2019 | 01:05 PM
2Rismo2's Avatar
Doesn't sound like they fixed the injector issue post 2015 year...
Old Jun 29, 2019 | 12:57 PM
Hisssyfit's Avatar
So I just got back from the dealer and they’re making me bring it back in Monday night so that they can cold start it on Tuesday. Apparently cylinder three is still having a misfire. Also told me that Honda does not give out loaner cars? I’ve read about the 2015 models fuel injector issues but was wondering if anyone has any more information about that. I’m a small lady and I feel like they are trying to pull the wool over my eyes because I’m not that well-versed in cars. My car is less than 2 years old :/
Old Jun 29, 2019 | 02:15 PM
Brain Champagne's Avatar
Loaner cars are up to the dealer. Typically it's something you negotiate when you buy it (and then it'd be just for that dealer).
Old Jun 29, 2019 | 02:27 PM
Hisssyfit's Avatar
Damnnnnnnnnn! Why a dealer gotta be like that? Thanks for the information Brian!
Old Jun 29, 2019 | 03:27 PM
If your car was purchased new and is less than 2 years old and has 36K miles or less, the problem should be covered by the bumper to bumper warranty. And I think the power train warranty is 5 years or 60K miles. The injectors are part of the engine which is part of the power train. Please keep us posted
Old Aug 20, 2019 | 01:10 PM
Gringoface's Avatar
2018 FIT EX (12500 miles)
Same issue here. Got all the lights a couple months ago - dealer said was a "misfire, probably due to bad gas, it happens. We've checked the database and there isn't an ongoing issue" It sounded like B.S. when he was saying it, but let it go. It has happened again today, and will bring it in this week. Fuel Injectors, Coil pack,.. anything else I should specifically ask them to check before accepting "it happens?"
Old Sep 13, 2019 | 12:33 PM
ErniePC12's Avatar
I just had this issue as well, I was told that my fuel injectors need replacing.
I am told that they have to order the parts but that they are covered under the warranty
I have a 2018 Fit Sport, Manual transmission. I have 47,256k miles on it.
Old Sep 13, 2019 | 01:48 PM
2Rismo2's Avatar
Extended warranty? Or is this being covered in the drive-train warranty?
Another 2016+ model with this issue. To me, the theory that this was fixed after 2016, is FALSE...
Old Sep 13, 2019 | 04:37 PM
woof's Avatar
All the complaints seem to be with 2018 models. I don't see 2017's being mentioned. Of course i believe they were built in Japan and maybe the fuel injectors came from a different supplier.
Old Jan 9, 2021 | 09:56 AM
King696's Avatar
2019 Honda Fit /40000miles
ALL DASHBOARD LIGHT ON
wright now am with dealership
Old Jan 11, 2021 | 12:51 PM
King696's Avatar
Emission warranty
Please check for Honda Fit 2019 emissions warranty
even engine filter, spark plugs all are coming under this
Thanks
Here are they are
Thanks in advance
Old Aug 30, 2021 | 01:21 PM
Hisssyfit's Avatar
Two years later and all my lights are back on! I dropped it off at the dealer and am waiting to hear back though I am pretty sure what they are gunna say... siggggggggh
My dealer also informed me that credit cards payments are now subject to a 3% fee. Yup that totally makes sense.
Old Aug 30, 2021 | 10:36 PM
Fuelish's Avatar
That/s crazy .... like everyone can just pony up however many thousands for something...... and I refuse to believe that injectors have to be installed as a "matched set" ... these things are mass produced, ain't nobody taking the the time to cross check them against each other to see if they're matched. If they're produced to spec, should be able to replace a faulty injector......Honda money grab/scam''...although we've been lucky so far....and probably just jinxed myself haha
