Konig hypergram 15x7.5 et35
Old Dec 28, 2021 | 05:01 PM
Ge888's Avatar
Want to buy a set of Konig Hypergrams but the smallest size is 15x7.5 et35. Does anyone have experience with these or know if I’ll have rubbing issues? My fit is 100% stock and I don’t plan on lowering it or anything. Mostly worried the front will poke out to much and hit the fender going over bumps.
Old Dec 31, 2021 | 04:24 AM
EvoKnvl's Avatar
What tire size are you planning on running? I assume this is for a 2nd Gen GE8? If you're on stock height, you probably won't hit the fender. If you're lowered, then you probably will. Even at -2.5 on the front, I can rub the fender liner on the front. The rear will slightly rub as well. I am lowered though.
Old Dec 31, 2021 | 05:40 AM
GrE8_Fit's Avatar
What size would you recommend? 195? 185/55 to much of a stretch? I'm in a similar boat as OP.
Old Dec 31, 2021 | 05:47 AM
EvoKnvl's Avatar
I should have clarified. I'm running 205/50 R15, which is what I see most people run. Diameter is a little smaller, but much easier to find tires in that size, vs 205/55.
Old Dec 31, 2021 | 03:20 PM
Ge888's Avatar
Yeah it’s a 2009 fit sport. I figure if run 205 50 15 tires. Not lowered, plan to keep the stock height, just want to get lighter, wider, better looking wheels. I want 15x7s but I can’t find any that I like at a good price that are lightweight. Also so many aftermarket wheels have such small offsets I think they’ll poke out too much.
Old Dec 31, 2021 | 03:26 PM
EvoKnvl's Avatar
You can check out the Enkei RFP1. They make them in 15x7 et35. Lightweight and a reasonable price as well.
Old Dec 31, 2021 | 03:32 PM
Ge888's Avatar
yeah I’ve seen these a lot maybe I just buy them even though I’m not a huge fan of the looks. Do you any idea how these fit with stock suspension? Im hoping to get something flush maybe a tiny bit of poke but not a lot. Of coarse I can add spacers if there to far in.
Old Dec 31, 2021 | 03:39 PM
EvoKnvl's Avatar
I believe your stock wheels are 16x6 et53. So at 15x7 et35, it would push outwards another 31mm. The 15x7.5 et35 (Konig) sticks out an extra 37mm over your stock wheels.
allgocrx
Feb 16, 2009 11:04 AM
The BOM
Jan 12, 2009 01:24 AM
Sam Misled
Dec 11, 2008 11:37 AM
power121
Oct 28, 2008 07:34 PM
jhoprodie5
Sep 7, 2008 12:15 AM
