Slow speed rattling problem going over little bumps
Old Sep 10, 2025 | 05:33 AM
Doctor X's Avatar
Question Slow speed rattling problem going over little bumps
08 Fit.
I wonder what this is? It almost sounds like a slightly loose strut but they seem to be tight. It started out on the passenger side and now both sides are rattling like crazy. The noise seems to go away at higher speeds.
Old Sep 17, 2025 | 10:38 AM
doctor J's Avatar
IIRC you did the starter, make sure everything is nice and tight
Old Sep 18, 2025 | 03:33 PM
bori's Avatar
Is this a somewhat short rattle or a single *CLONK* ?
I had both stabiliser bar links broken at some point to the bar was basically bouncing on the control arms over every road bump.
Just in case, the links are parallel to the shocks, you can grasp them when the wheels are turned to check if they're correctly attached.
Ditbu
May 3, 2022 02:57 PM
pebbler9072
Feb 8, 2021 05:09 PM
siguy
Feb 20, 2017 10:08 PM
Blueputtputt
Jun 18, 2009 01:47 PM
bittermelon
Mar 27, 2008 03:46 AM
