2015 Honda Fit crank No start… VVT? Timing chain?
Old Mar 4, 2026 | 04:36 PM
Revo39564's Avatar
Bought a mechanics special . He replaced the fuel pump and gave up. Scanned the codes and have 4 codes. My plan is first change the oil, then remove and test camshaft position sensor, then if it continues check VVT oil solenoid/ vvt actuator and timing chain …..any input , recommendations ?
Old Mar 5, 2026 | 03:35 AM
Chitown Fit's Avatar
How Many Miles?
How many miles?
Car may not be worth fixing being a "Mechanic's Special".
Have the car looked over at your local Honda Dealer.
Old Mar 5, 2026 | 07:22 AM
Revo39564's Avatar
I enjoy working on vehicles .I can repair it. We would rather spend $300 on parts myself then 4000 at the dealer.
Old Mar 5, 2026 | 08:51 AM
Revo39564's Avatar
after reading the forum I am going to do a compression test and run a scope into the bore. If valves bent will not change the chain lol
Old Mar 6, 2026 | 03:51 PM
Revo39564's Avatar
It’s running
Originally Posted by Chitown Fit
How many miles?
this was the cause of the no start issue… oil control solenoid .
it was clogged with pine debris….. it’s running great now.
Old Mar 8, 2026 | 11:07 AM
bobski's Avatar
You're sure it's plant material? Those fine screens are great at catching debris in the oiling system. Though this is all post-oil-filter, so there shouldn't be any debris at all unless the oil filter was completely clogged (the filter's over-pressure bypass operating) or the filter was defective (bypassing all the time). There's a bigger story here - oil was never changed, maybe a crank or rod bearing failed. Deliberate engine abuse?
I would immediately change the oil filter, run an oiling system flush product, change the oil and filter (again). Then get to doing a bunch of the maintenance/tune-up items like valve adjustment and induction cleaning. The amount of build-up on surfaces under the valve cover should tell you about the oil change history (the flush won't remove all of it).
Old Mar 8, 2026 | 11:55 AM
No Oil Change?
Engine is toast.
No wonder it's a Mechanic's Special.
Old Mar 8, 2026 | 01:05 PM
bobski's Avatar
Engine is toast.
Possibly. With any luck, the flakes are something soft enough to not damage the crank bearings. Clean it up without spending too much money - do health checks like compression and leak-down. Drive it a bit to see if it burns oil.
Old Mar 8, 2026 | 07:30 PM
Revo39564's Avatar
it was friable like bark and was also in engine compartment. Yeah already dumped oil and filter.will run and recheck solenoid. Next check valves and chain and guides. Pistons looked good with scope and compression tested ok.
Old Mar 8, 2026 | 07:44 PM
Revo39564's Avatar
if it’s post filter, then the only thing I really could be would be the timing chain guides. It was soft . It wasn’tmetal. There’s no metal shavings at all anywhere.
Old Mar 8, 2026 | 11:01 PM
Revo39564's Avatar
Engine is toast.
frequent oil changes per carfax….. last change 05/25 at dealer……. Engine will be butter not toast lol
Old Mar 9, 2026 | 12:30 AM
bobski's Avatar
Somebody hid their stash in an oil filter that got installed on your engine?
Soft like rubber? Cheese? Road grime?
Old Mar 9, 2026 | 08:07 AM
Revo39564's Avatar
surprisingly it had a Honda filter ….. but with autolite iridium plugs…. An enigma lol
Like small bark like pieces that break apart easily …. cleaned with MAP sensor cleaner no grime/ no metal/ just the fragments …..
Old Mar 9, 2026 | 08:33 AM
Revo39564's Avatar
it looks like a spool valve filter can fail and cause fragments as well. And some engine oil additives can damage them
Old Mar 9, 2026 | 09:49 AM
Revo39564's Avatar
nope that was clean ………
Old Mar 9, 2026 | 10:33 AM
bobski's Avatar
I've never heard of that. Where are you getting this stuff? The chain guides are in the crank case, which is pre-pump and pre-filter.
My current thought is that the substance is oil-saturated vermiculite, which was used for oil spill cleanup. Still no idea how it got into the oiling loop, outside of an extremely careless mechanic.
Old Mar 9, 2026 | 02:31 PM
Revo39564's Avatar
If it’s anything like gardening vermiculite, it wasn’t definitely not that…..
it was a Honda oil filter those are domed internally a piece of pine bark fell down into the filter, changing it…… or maybe it’s some type of gasket from somewhere…..
or maybe the oil pump screen has a hole in it who knows……. maybe it was sludge buildup that carbonized./oxidized……. maybe on a prior filter the bypass valve was defective. The spoon filter was clear , zero build up …..
Old Mar 9, 2026 | 04:22 PM
woof's Avatar
Could be from a cheap oil filter left on too long. Cellulose filter material might have deteriorated and fallen apart. If the owner was going to sell it he might have then changed the oil and filter so it would look good to a prospective buyer, but the original debris never got cleaned out.
Old Mar 9, 2026 | 05:44 PM
Revo39564's Avatar
l
yeah, it could be. It was right under 5000 miles since its last oil change 5/5/25 at a Honda dealership with a Honda filter before that oil change placed used. I’ll pull the ortho an aid and recheck it for debris and see in a couple hundred miles or maybe pull the oil pan I’ll put it on the list of things. I’ve gotta do …. Lexus needs a valve cover gasket, minivan needs ball joints …… etc., etc.
Old Mar 10, 2026 | 11:49 AM
Revo39564's Avatar
after looking at the solenoid pic I think I figured it out. The previous owner of the car was dealing with a cylinder misfire they replaced one of the coil packs….. oddly enough on cylinder 1 not 4……. Box was in car. Then they paid a mobile mechanic who put in a fuel pump that didn’t help. At some point in this process someone pulled out that oil control solenoid, and contaminated it with a pine bark accidentally then put it back in, and the car would not start…… if you look closely at the picture, you can actually see plant material that would not have survived the oil circulation….. sad part is the misfire was easy. Don’t use autolight plugs.
