Bad START Button
Old May 5, 2026 | 08:25 AM
SilverEX15's Avatar
Bad START Button
I read something about this a few weeks ago, and I think I have that problem. When I press the START button, sometimes nothing happens. I have to press it two or three times to start the car. From what I remember there is a lot of disassembly required.
EDITED: I just found this - start button on 2015 honda fit not working - Google Search
Old May 5, 2026 | 03:00 PM
Chitown Fit's Avatar
Start Button Issue.
Honda knew about the start button issue.
There was a free Honda Dealer fix for this.
If this is happening to you now you may be too late for the Honda Dealer to replace your start button for no charge.
Go to your local Honda Dealer to see if you still qualify to get this fixed for free.
Old May 5, 2026 | 03:05 PM
SilverEX15's Avatar
Oh, I love these secret repairs. They go back decades. My dealer is trying to figure out how he can charge me just for talking to him. 😁
I'll have to rely on YouTube. The problem with this is that I could be stuck 100 miles from home. This is why all cars should have ignition switches - but that would cost the makers money
Old May 5, 2026 | 03:21 PM
Start Button Fix.
I had mine replaced a few years ago.
My start button required more and more push starts to start my Fit.
I went to my local Honda Dealer ready to spend hundreds of dollars to fix this.
To my surprise the Honda Service Tech told me there was a recall for all push start buttons to be fixed for free.
Since then my Fit starts after the first push start.
No more second push starts anymore.
Old May 5, 2026 | 04:15 PM
SilverEX15's Avatar
I never received a recall notice, and no recalls are outstanding on my car. They just replaced the button? I had heard something about arcing and cleaning. I'll look on YouTube. I'll buy a new button.
EDITED: This guy removed the button, removed the back, sprayed WD-40 inside it, and put it back into the dash - under ten minutes. His car, like mine has the little yellow warning key in the display.
EDITED AGAIN: I don't know year that quick repair was for, but the 2015 and the 2020 require a ridiculous amount of disassembly. I guess that's what you call progress.
Old May 5, 2026 | 05:22 PM
woof's Avatar
I think recall is the wrong term. For 2015-17 Fits it was an extended warranty of 125,000 miles or 9 years from original date of purchase.
Warranty extension
Old May 5, 2026 | 07:17 PM
bobski's Avatar
WD-40 is NOT an electronics-friendly product. It evaporates over time, so it's not a good lubricant, or a particularly good metal protectant. There are better alternatives for every application of WD-40, unless you're maintaining your factory-fresh, period-correct Atlas missile.
Having been stuck 70 miles from home with a bad ignition switch, it's not the solution you think it is. If you're worried about electrical problems disabling the car, order one each of the relays in your fuse boxes (a few are unique, most are a single part used in multiple positions), a good replacement fuse kit (Littelfuse, Bussmann, Eaton all come to mind), a replacement Start button (new or from a salvage car), and the item you'll get the most use from (once or twice every 5 or so years): a jump-start box. There's some perfectly good lithium jump-start power banks out there - "Torque Test Channel" has done a few videos testing them.
For tires, an air pump and a plug kit. Learning to plug tires (it's not complicated) will save you a LOT of time and money. Catch it at the right time and you won't even need to remove the wheel.
Old May 6, 2026 | 08:20 AM
SilverEX15's Avatar
Having been stuck 70 miles from home with a bad ignition switch, it's not the solution you think it is. If you're worried about electrical problems disabling the car, order one each of the relays in your fuse boxes (a few are unique, most are a single part used in multiple positions), a good replacement fuse kit (Littelfuse comes to mind), a replacement Start button (new or from a salvage car), and the item you'll get the most use from (once or twice every 5 or so years): a jump-start box. There's some perfectly good lithium jump-start power banks out there - "Torque Test Channel" has done a few videos testing them.
Right! I'm surprised to see so many people using WD-40 as a universal spray. "WD" stands for "water dispersion," and it was designed for rockets - after thirty-nine attempts. I try to use the appropriate chemical for the job. I bought a gallon jug of WD-40 and use a spray bottle for it. That's sooo much cheaper.
"The original WD-40 formula, created in 1953 by Rocket Chemical Company, is a closely guarded trade secret that remains unchanged and unpatented to protect its formula. It was designed for the aerospace industry to displace water and prevent corrosion, notably on the Atlas missile. While the exact recipe is kept in a bank vault, it is fundamentally a blend of petroleum-based lubricants, solvents, and carbon dioxide."
Old May 6, 2026 | 10:16 AM
woof's Avatar
Yes, WD-40 is a good anti-rust product and a light weight lubricant but it doesn't have a long life. Other things like fluid film are apparently all around better especially for rust protection.
I was at an airport about 40 years ago and the plane couldn't depart because one passenger's seat wouldn't stay upright and kept falling all the way back, A technician ran on to the plane carrying a can of WD-40 and he quickly stuck the nozzle straw into the seat mechanism and gave it a few squirts. Problem solved, the seat now latched upright OK. I have no doubt that the seat would be marked for maintenance in the not too distant future and the proper lubricant applied because the WD-40 wouldn't last too long.
Old May 6, 2026 | 10:30 AM
SilverEX15's Avatar
Fluid Film is great. I bought a gallon and a sprayer to do both cars - many years too late.
From my experience watching air crash investigations, "marked for maintenance in the not too distant future" often never arrives. The FAA will recommend or decree that a modification must be made for safety - within three years. Three years pass, and many planes were never modified. Profit over safety.
Old Jun 2, 2026 | 07:52 AM
SilverEX15's Avatar
I called Honda yesterday, and he said that replacement would not be free. They have replaced a lot of those switches in Passports. He suggested that it's the key fob battery - but it isn't. Then he told me to bring it in so they could determine the problem. I know what the problem is. If I did bring it in, they would charge me $250 to tell me I need a new button, and replacement would cost only $800. 🤣
He was having trouble with his computer, and he was going to call me back with an appointment time, but he never did. Just as well.
I think cutting an access opening below the switch is the way to go. The alternative is to remove everything from the dash - driver to passenger. Ridiculous!
Old Jun 2, 2026 | 08:32 AM
Free Push Start Button Fix.
I never heard that this was a limited time offer.
Look to see if another Honda Dealer can fix this for free or less than what your were told at this Honda Dealer.
Old Jun 2, 2026 | 09:57 AM
SilverEX15's Avatar
Yes, I'm calling another one today.
Old Jun 2, 2026 | 11:00 AM
Start Button Fix.
Good.
Hopefully you'll get your start button fixed for Free.
Good Luck.
Old Jun 2, 2026 | 11:08 AM
Talked With My Honda Service Tech.
He said it depends on the mileage and year of your car.
He would have to look up your car vehicle identification number to see if your car still qualifies for the free start button fix.
SilverEX15's Avatar
Good.
Good Luck.
Hopefully, I'll win the lottery without buying a ticket. 😉
Old Jun 2, 2026 | 11:09 AM
SilverEX15's Avatar
When I told him it was a 2015, he said it was too old.
Old Jun 2, 2026 | 11:35 AM
Out Of Warranty.
Then you'll have to pay for this fix.
I guess I got lucky when my push start button fix was free.
Old Jun 2, 2026 | 11:37 AM
SilverEX15's Avatar
What year was the car, and when was the repair done?
Old Jun 2, 2026 | 12:08 PM
Start Button Free Fix.
2015 EX Stick.
I found my post about when I got mine fixed for free.
December 10, 2020.
