2015 Honda fit VTC actuator removal
Old May 24, 2026 | 07:36 PM
Revo39564's Avatar
Any tips about removing this VTC actuator….. tried heat, breaker bar…. No luck……difficult to hold cam with wrench… next step I will unbolt cam and take to a machine shop
Old May 25, 2026 | 05:25 PM
t-rd's Avatar
What are you doing to it? You can just replace the spring inside the actuator.
Old May 25, 2026 | 06:57 PM
Revo39564's Avatar
I finally got it. Used an adjustable crescent when the open end wrench failed. Was actually easy with wrench …….
Old May 25, 2026 | 08:13 PM
Revo39564's Avatar
all the kings horses, and all Kings men couldn’t put that vtc actuator back again…… the timing belt was stretched, and it jumped one tooth timing due to a bad vtc actuator that went bad because of a bad oil control solenoid…… The guy changed his oil religiously not a drop of sludge in this engine.
Old May 25, 2026 | 09:30 PM
bobski's Avatar
I get the feeling there's several questions that Honda doesn't want answered about this engine's timing system.
Old May 25, 2026 | 10:31 PM
Revo39564's Avatar
it’s a pain for sure. New Vtc actuator received in the locked position too ….. wonder how many folks don’t unlock them ….
Old May 25, 2026 | 10:57 PM
Chitown Fit's Avatar
When You Think You Know It All.
[img alt="The Honda Dealer doesnt look so bad now,
Does it?"]https://cimg4.ibsrv.net/gimg/www.fitfreak.net-vbulletin/446x498/img_20260225_111028_5532653cc377e3f7cfc82e3d4d970f 0b1c6be958.gif[/img]
The Honda Dealer doesnt look so bad now, Does it?
Old May 25, 2026 | 11:25 PM
Revo39564's Avatar
Already have the new VTC actuator , guides , cam gears and chain on…… the pic above is the new one…….. dealer looking good….. no not really ….
Old May 25, 2026 | 11:31 PM
bobski's Avatar
The actuator unlocks itself when oil pressure gets applied to the... timing advance side of the actuator?. Then locks itself when moved all the way back to the resting position. Or at least it's supposed to - the spring pushes the plunger into the lock position as long as there's no oil pressure in the pin bore counteracting the spring. The whole VTC rattle problem comes from the actuator not locking itself at engine shut-down.
Actually, installing the chain with the actuator unlocked could result in the intake cam being off a few teeth.
edit: I take that back. As long as you set the timing based on the cam gear marks rather than relying on the camshaft locking pins, it should come out all right. Though it will rattle on the first startup if the actuator isn't locked.
Old May 26, 2026 | 12:45 AM
Revo39564's Avatar
? you put the unlocked VTC actuator on the camshaft and torque it to spec. Then you rotate it to lock it in…. Then place timing chain ,etc. if you torque a locked VTC actuator you can sheer the pin…….
Old May 26, 2026 | 09:12 AM
bobski's Avatar
The service bulletin covering VTC replacement (A16-088) makes no mention of unlocking the actuator. It expects you to remove the camshaft for actuator removal and installation, and warns against using an impact wrench. Nothing about unlocking the actuator.
Old May 26, 2026 | 09:18 AM
SilverEX15's Avatar
Honda charged my son $2,500 to do that!
Old May 26, 2026 | 09:20 AM
t-rd's Avatar
Seems like you let that rattle go for a long time.
Old May 26, 2026 | 10:11 AM
Revo39564's Avatar
It was in the Chilton manual. I suspect the Mexican plant was installing them and torquing them in locked which damaged the weak spring…….VTC actuators are torqued unlocked ……
Old May 26, 2026 | 10:14 AM
Revo39564's Avatar
check out this link on a different Honda engine …… about unlocking actuator
https://static.nhtsa.gov/odi/tsbs/20...87883-2280.pdf
Old May 26, 2026 | 10:15 AM
Revo39564's Avatar
I didn’t …. lol .. previous owner
Old May 26, 2026 | 10:23 AM
Revo39564's Avatar
Was that the price to replace just the VTC actuator?
Old May 26, 2026 | 10:31 AM
SilverEX15's Avatar
But it was cheaper for Honda to have them assembled in Mexico, and that's all that really matters.
Old May 26, 2026 | 10:35 AM
t-rd's Avatar
what is the milage on the car?
Old May 26, 2026 | 10:58 AM
Revo39564's Avatar
168k ….. oil pan looked clean no sludge
