help rough idle
Old Jan 25, 2007 | 03:36 PM
skyludeboy's Avatar
help rough idle
hi guys i a honda jazz owner from the uk i need help with my car it has a really rough idle and does not go over 2000rpm and the engine check light is on i stuck in a diognostic reader in the port gave me 3 codes p0123, p0223 and p1247 i need to know how to fix these codes as i cannot drive my car how do i fix throttle sensor circuit a input high and throttle sensor circuit b input high all help will be appreciated as i cannot find any answers from no where
thank you
Old Jan 25, 2007 | 04:50 PM
kentris's Avatar
is the car still under warranty?
Old Jan 25, 2007 | 08:23 PM
03DSM-RSX's Avatar
Frequent FitFreak Poster
A P0123 code means that the the car's computer has detected that the TPS (throttle position sensor) is reporting too high a voltage.
A code P0123 may mean that one or more of the following has happened:
  • TPS not mounted securely
  • TPS circuit short to ground or another wire
  • Faulty TPS
  • Damaged computer (PCM)
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, carefully inspect all wiring and connectors that lead to the TPS. More than likely the problem is with the TPS wiring. Check the voltage at the TPS (refer to a service manual for your vehicle for this specific information). If the voltage spikes or is too high (over 4.65 volts with key on, engine off), then that is indicative of a problem. Carefully trace each wire from the TPS wiring harness to check for breaks, rubbing against other components, etc.
P0233 Fuel Pump Secondary Circuit Intermittent
couldnt find p1247. search google for codes and possible solutions.
Old Feb 9, 2008 | 11:05 AM
skyludeboy's Avatar
where about is the tps located this is the main thing i cannot find its not on the throttle body is the the triangular black box with a cable connected to it underneath the battery
gadfly
Jul 27, 2015 07:51 PM
markielowski
Jan 2, 2011 03:08 PM
pavelruss
Aug 9, 2009 03:42 PM
redfit_pr
Jun 16, 2009 02:50 AM
skyludeboy
Feb 9, 2008 11:01 AM
