Re: 92 Civic, no heat?
Old May 4, 2005 | 11:16 AM
KWW
Guest
Posts: n/a
Thanks guys! I will check ASAP.--
KWW
"Abeness" <news@nada.x> wrote in message
news:UcCdnTmied0hlpzfRVn-2A@rcn.net...
> KWW wrote:
>> Have '92 Civic LX, 4 dr automatic with A/C. I've kept the cooling system
>> correctly (drain/fill with Honda antifreeze- following directions on
>> bottles).
>> OK, the A/C needs to be recharged, but if we turn OFF the A/C button and
>> the
>> engine registers that it is warm (on the gauges), shouldn't there be SOME
>> sort of heat coming from the system?
> In addition to the other suggestions, first check to be sure that your
> coolant level hasn't dropped due to a leak. Too little coolant can also
> lead to no heat, and no heat can be an early warning sign that can help
> you catch low coolant before serious engine damage occurs.
TeGGer®
Guest
Posts: n/a
"KWW" <kwalker@nospamaircooled.net> wrote in
news:wf-dnTFgXONhKp_fRVn-pA@comcast.com:
Almost forgot to post the promised pics:
http://www.tegger.com/hondafaq/overh...ic-heat-valve-
(should be all on one line)
and
http://www.tegger.com/hondafaq/overh...heat-valve.jpg
TeGGeR®
Viper143
Sep 14, 2005 08:30 AM
Abeness
Aug 4, 2005 09:34 AM
DesignGuy
Jul 20, 2005 06:23 PM
enravi
May 4, 2005 04:44 PM
Scott Miller
May 4, 2005 11:16 AM
