Weird noise at 1900 RPM
Old May 4, 2005 | 11:16 AM
Jimmy
Guest
Posts: n/a
Hi All,
Something odd has been happening with my '98 Acura Integra (base model,
manual transmission). When the RPMs begin to drop and reach 1900 RPMs,
there is a sound I hear that seems to be two surfaces rubbing or grinding
against each other. It last for less than a second but consistently occurs
whether the car is in neutral or in gear.
Anybody have a clue as to what this might be?
Any info would be appreciated.
SoCalMike
Guest
Posts: n/a
Re: Weird noise at 1900 RPM
exhaust/catalyst heat shield?
Jimmy
Guest
Posts: n/a
Good guess. My mechanic just called and mentioned it as the potential
problem.
What would be extent of the repairs if you both are right? What would be
involved and do you think it should be costly?
"SoCalMike" <mikein562athotmail@hotmail.com> wrote in message
news:646dnTKLNN2MW57fRVn-sA@comcast.com...
Mista Bone
Guest
Posts: n/a
Exhaust downpipe rattle, quite common.
"Jimmy" <demetri@cae.ca> wrote in message news:cu0et2$hc8$1@dns3.cae.ca...
> Hi All,
occurs
tony kujawa
Guest
Posts: n/a
"Jimmy" <demetri@cae.ca> wrote in message news:cu0huh$439$1@dns3.cae.ca...
> problem.
Nothing a few hammer hits and screwdriver prys can't take care of. I just
ripped the F-er off after a while. I've done this on a 97 Civic, 93 Escort
and 93 Bonneville in the past. You can try to weld them back up, but the
rattle always returns.
Jimmy
Guest
Posts: n/a
Thanks for info. I've heard of the problem before but I was perplexed when
the sound was occuring at a specific RPM. I guess when the engine hit 1900
RPMs, this condition coincided with some natural frequency.
"tony kujawa" <tjktjk2003@yahoo.com> wrote in message
news:36i47jF52av2vU1@individual.net...
> > problem.
be
Escort
gmccx
Guest
Posts: n/a
Would you think that might possibly be what I have been hearing at about
4500 RPM in 5th gear for nearly ever? I posted about it here once
before wondering if it was engine pinging of some sort. But at least
two mechanics I trust have told me that is not the case and not to worry
about it... so I mostly don't.
>>Hi All,
> occurs
George
http://people.delphiforums.com/gmcc
SoCalMike
Guest
Posts: n/a
possibly. different things resonate at different frequencies.
hunkman
Guest
Posts: n/a
Unfortunately it sounds like a very common problem that occurs in
Acura Integra and Honda Accord alike. I would take the car in for
transmission overhaul as soon as possible to prevent further damage.
See other posts on transmissions and Accords.
Good luck...
"Jimmy" <demetri@cae.ca> wrote in message news:<cu0et2$hc8$1@dns3.cae.ca>...
> Hi All,
vtecracing
Guest
Posts: n/a
There could be a number of possibilities that are causing that sound.
Check with the exhaust manifold bolts and hangers from underneath your
vehicle. Next double check your ignition timing and also you alternator
belt. Hope this helps.
For all your Honda and Acura needs, check
out http://www.trackspeedracing.com. They carry a wide selection of
dyno proven racing products.
Grahame
Aug 26, 2005 01:47 PM
sweety783
Jun 28, 2005 04:04 PM
Al Franz
Jun 27, 2005 10:39 PM
Shawn McClelland
May 4, 2005 04:44 PM
ravelation
May 4, 2005 11:16 AM
