2001 prelude cruise control kaput/ squeky steering column
Old May 4, 2005 | 11:16 AM
zZero
Guest
Posts: n/a
After a couple of years of a squeking steering column (related?)usually
only in Winter, the cruise control wouldn't come on yesterday. What to
check?
J.
Guest
Posts: n/a
Re: 2001 prelude cruise control kaput/ squeky steering column
My 99 lude manual has 11 pages on the CC and a full page of diagnostic
probing tests at the Control Unit's 14 pin harness connector (mounted
somewhere between the driver's right foot and the radio-have to remove the
dashboard lower cover) to rule out the following components:
-main switch on dash (it and the LED are "on", right?)
-clutch (M/T) and brake switches / adjustment
-gear position switch (A/T)
-set/resume steering wheel switches
-acutator assy & solenoid (under hood)
-fuse #41 (15A) under hood (same as horn fuse)
-fuse #31 (15A) under dash
-vehicle speed sensor (VSS)
-misc. open wires/poor grounds
I suspect the '01 lude's CC will be very similar or identical.
J.
"zZero" <jsk2@excite.com> wrote in message
news:1107714523.592125.269460@f14g2000cwb.googlegr oups.com...
> check?
thomas.jacobs@dva.state.wi.us
Guest
Posts: n/a
I have a 98 and the CC stoped working for a week then started working
again. Havn't experienced the problem again.
zZero
Guest
Posts: n/a
my baaad. Musta hit the cruise button on dash when it warmed up
recently (opened the roof). Forgot it was there. All is well but the
squeak.
radioarno
Dec 12, 2017 01:38 PM
allTRACway
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Mar 3, 2016 10:10 PM
robcollins5
Nov 8, 2014 01:45 PM
jnylen0
Jan 5, 2014 09:09 AM
eljuero
Nov 14, 2009 02:00 PM
