transmission shifting
Guest
Posts: n/a
i have a 97 Accord Coupe SE w/ an automatic transmission. it has 118,000
miles on it. the problem is that it shifts hard. like, i can feel it
shifting EVERYTIME it shifts. i've changed the transmission fluid at the
Honda dealer several times now and so i know it's not the fluid. any
suggestions?
suggestions?
Guest
Posts: n/a
Re: transmission shifting
Hondas shift hard. It prolongs the life of the clutches. You will feel
every time it shifts. It shouldn't jar the teeth out of your head though.
"braxmed" <braxmed@gmail.com> wrote in message
news:34582753d04671da49a3d2ab215cfa8e@localhost.ta lkaboutautos.com...
> suggestions?
> suggestions?
Guest
Posts: n/a
> suggestions?
I thought you were going to say you had it done at Sears / MonkeyLube /
Canadian Tire. You're absolutely sure your dealer put in Honda Z1 ATF ?
'Curly'
> suggestions?
'Curly'
Guest
Posts: n/a
so, automatics have a clutch? i know i sound REALLY dumb for asking that
but please just humor me. and i don't think i should feel it regardless!
it should be smooth. just like my mom's 2000 CR-V and my dad's 98 3.0CL
Premium. i have friends who have the same year and theirs shift
wonderfully. can't even tell it's shifting. have to watch the RPMs, or
listen.
listen.
Guest
Posts: n/a
> listen.
Yep, it's got clutches inside. I was suggesting you check your reciept
to see if they billed you for Honda Z1 tranny fluid. If you use anything
else (generally) they will shift like slamming a door . . . Wham.
'Curly'
> listen.
'Curly'
Guest
Posts: n/a
> listen.
etiquette: quote the points to which you're responding.
yes, the 98's & earlier can "shift hard". later models of honda retard
ignition effectively "throttling back" when shifting up, like in f1
transmissions. very smooth they are too.
yes, automatics have many clutches. 4-speed hondas have 4 main clutch
packs - 1 for each speed, together with a torque converter lock-up
clutch & 1-way clutch & other doo-dads for reverse. there's all kinds
of stuff on the web about how automatics work, but most is for planetary
gearboxes, the most common sort. hondas are different being essentially
a standard box with clutch packs instead of synchros - potentially more
efficient but less able to shift really high torque, [which should be a
non-issue with ignition retard or even "fly by wire"].
hard shifting is usually because non-honda transmission fluid has been
used. are you certain it was dealer serviced with the correct fluid?
checked the service receipt?
> listen.
Guest
Posts: n/a
Your throttle pressure cable might be a little tight. It could make the
tranny think you are pressing harder on the accelerator than you really are.
Under light throttle pressure at what rpm is it shifting from 1st to 2nd and
from 2nd to 3rd?
news:450ad1a2bc6f1d833a89b485c3cb488c@localhost.ta lkaboutautos.com...
> listen.
from 2nd to 3rd?
> listen.
