Vtec sound
Old Apr 2, 2007 | 04:47 PM
MarkB's Avatar
Vtec sound
Has anyone heard the vtec engage? ( You would have to have an intake to hear it probably)
I've been in cars with D seriers motors, B series and K's and you can most definately hear Vtec engage. I just installed a CAI and I swear I cannot hear the lobe difference or change. Doesn't Vtec in the L15 kick in below 3K rpm when above 50% throttle position? Either which way I cannot hear it. Maybe it's so mild of a difference that it's inaudible?
Old Apr 2, 2007 | 05:20 PM
JDMchris.com's Avatar
I run THIS
Old Apr 2, 2007 | 05:35 PM
MarkB's Avatar
Yeah I've seen that thread before. Nothing about anyone hearing it. So I guess it's a non issue..
Old Apr 2, 2007 | 06:09 PM
George02's Avatar
Unhappy
u can hardly hear it at all. I dropped my vtec down to 4800rpms and couldn't hear it. jus feel it. I use to own an s2000 so I do sure miss it lol
Old Apr 2, 2007 | 06:16 PM
07TaffetaFit's Avatar
There is no lobe changeover on the L15... I honestly dont know why they called it VTEC, because everybody assumes is the traditional VTEC like in the D/B/K series... if Im not mistaken, all that happens is the engine switches 4 valves on @2800rpm. So you have 12 valves until 2800rpm and then it switches to 16 valves, basically for the sake of gas mileage.
That being said, you arent going to hear the infamous "VTEC cam lobe switchover", everyone is trying to refer to in this and other threads, when the car hits 2800. JEEZ!!
Old Apr 2, 2007 | 07:18 PM
MarkB's Avatar
I would have to agree with why they had to call it Vtec when it's really a half assed version.
Oh well it is a motor designed for ultra wicked fuel economy first. and Fun second
Old Apr 2, 2007 | 07:42 PM
George02's Avatar
hey you dont get the sound but you do get the kick when you set it lower and get more than 500rpms of "vtec"
Old Apr 2, 2007 | 07:46 PM
redfit_pr's Avatar
if you take off the cat and the resonator you can heard it , and you get more free , so you get more power, later i will rec the sound to show you...
Old Apr 2, 2007 | 07:56 PM
MarkB's Avatar
I would like to hear this.
Thanks.
Old Apr 2, 2007 | 08:15 PM
George02's Avatar
im taking my cat off and replacing it with a test pipe also... ill post a vid of it
Old Apr 2, 2007 | 08:53 PM
rekcah's Avatar
Yea It is the same style vtech that my 06 civic hybrid has
Old Apr 3, 2007 | 08:14 AM
MarkB's Avatar
Originally Posted by claymore
Fit L15A1 engine does use two different cam lobes see this system description from the HONDA MANUAL. the sound is there just remove your air filter for a quick ride and you will hear it.
As per my first post I just put an intake on and I can't hear it change at all. When it is it must be very minimal.
Old Apr 3, 2007 | 02:02 PM
MarkB's Avatar
VTEC System L15A1 engine
  • The VTEC system changes the cam profile to correspond to the engine speed by the VTEC solenoid valve. It maximizes torque at low engine speeds and output at high engine speed.
  • The low lift cam is used at low engine speeds, and the high lift cam is used at high engine speeds.
This man speaks the truth!
Old Apr 3, 2007 | 02:14 PM
Black Widow g2's Avatar
don't expect an SOHC VTEC motor to give you the feel and sound that DOHC VTEC motors give you... There's a huge difference between the D and B series, just as with the L. I only hear and feel it because I'm familiar with what it does... so I know what to listen for.
Old Apr 3, 2007 | 10:31 PM
rekcah's Avatar
I just stick my head out the window and yell VEEEEEEEEETTTTAAAAAK
Old Apr 3, 2007 | 10:55 PM
I have SRI,Header,test-pipe, and cat-back and I have yet to hear the VTEC crossover you are referring to. I think you guys are all making this sh1t up in your mind just so you feel a little better about not getting an SI...haha
Old Apr 3, 2007 | 11:15 PM
George02's Avatar
haha maybe they gave you a none vtec fit!? jk
Old Apr 4, 2007 | 02:24 AM
quangalang's Avatar
why does it really matter if you can hear the vtec sound or not? does the sound make the car go faster or something? anyways, dont you guys know that if you cannot here the vtec cross over that means that the engine is tuned better and makes more power than one with loud vtec?
Old Apr 4, 2007 | 07:53 AM
MarkB's Avatar
This is more of a question of the mechanics of the L15A and these mechanics or moving parts do generate sounds. Now how do you figure it's better tuned if you don't hear it? I'm not thinking you are wrong I'm just wondering what your line of logic is that's all.
Old Apr 4, 2007 | 09:20 AM
Not that Im totally in agreement with him, but maybe he meant its a lot smoother transition instead of a blunt switchover? Anyway, I would imagine that the crossover point is alot incrimentally smaller on the Fit, than on a regular VTEC equipted car. It doesnt really matter, the car makes 109hp. I dynoed the other day and made 103fwhp and that seems to be one of the highest n/a Fits Ive seen dynoed on here...
