96 Accord slow drivers window???
Old May 4, 2005 | 11:16 AM
halo2 guy
Guest
Posts: n/a
To those of you that have experienced the typical slow drivers side power
window (up and down) on this car was the fix a new motor, lube the tracks or
something else?
Thanks in advance for your information.
motsco_ _
Guest
Posts: n/a
Re: 96 Accord slow drivers window???
> something else?
On the '97 - 2001 CR-V, the cure is to hose the lower (remove panel)
half of the tracks with silicone spray. That's what I read, anyway.
Does it CLUNK too, or just run slow?
'Curly'
halo2 guy
Guest
Posts: n/a
it just runs slow...I thought I had read something about bad motors on this
year of accords but I can't find it now. I guess I will just try to oil
everything first.
"motsco_ _" <"motsco_ _"@interbaun.com> wrote in message
news:421D6CDD.7040900@interbaun.com...
>> power window (up and down) on this car was the fix a new motor, lube the
>> tracks or something else?
> On the '97 - 2001 CR-V, the cure is to hose the lower (remove panel) half
> 'Curly'
Remco
Guest
Posts: n/a
Be careful running it when it is this slow.
It is often an indication that it may need some lubing (it is also
cold, so the old lube is thick) so causing the extra stress could strip
the motor gear.
Remco
motsco_ _
Guest
Posts: n/a
> everything first.
Um, don't use OIL. The next two owners of your Honda will still be
cursing yor name.
'Curly'
me
Guest
Posts: n/a
Mine is the same and so is my wife's 95. They have been running slow for
years and it gets even slower in the winter.
On my wife's we had it changed under warranty, in 98 I think, but the new
motor ended up doing the same shortly after.
I have them lubricated frequently by the dealer which temporarily alleviates
the problem. It is important to lubricate the tracks the glass runs on as
well with Teflon Spay to reduce friction. Don't use grease of any kind for
this or you will regret it for years.
There is no easy fix I'm told. The OEM motors that fit these cars (made by
Magna for Honda) are weak by design.
We just learned to live with it and help the glass along, up or down, but it
is a pain.
"halo2 guy" <somewhereovethe@rainbow.com> wrote in message
news:KNqdnVrvuMAf04DfRVn-1A@comcast.com...
power
or
> something else?
goalkp04
Sep 4, 2005 04:04 AM
hey_blue
Aug 31, 2005 11:30 PM
Milleron
Aug 20, 2005 12:57 AM
accord_owner@no.spam.com
Jul 15, 2005 10:30 PM
Matt Ion
May 22, 2005 10:16 PM
