[96 Accord LX] Intermittent Speedometer issue
Old May 4, 2005 | 11:16 AM
Paul Jackson
Guest
Posts: n/a
Hello,
The speedometer on my 96 Accord LX has started to behave erratically.
Sometimes it will work fine. Other times it will appear dead and come
to life after the car has been driven a while.
Other times it will start and stop randomly while driving.
The odometer seems to be working fine though.
Anyone have any idea what could be causing this and if this is a
relatively easy fix for a non-mechanic?
I have the Chiltons book 30152 and I can't find anything other than a
recommendation to check/replace the speed sensor wiring/unit. There is
nothing that shows you how to actually *do* it though.
TIA
halo2 guy
Guest
Posts: n/a
Re: [96 Accord LX] Intermittent Speedometer issue
if the odometer is working fine then I would think the speed sensor is ok
because I believe it utilizes the same input for both. I might be inclined
to believe the actual speedometer unit itself might be bad.
"Paul Jackson" <jackson.p.g@comcastdotnet.remove> wrote in message
news:t_KdnaUctMzlPb_fRVn-ug@comcast.com...
> Hello,
> Sometimes it will work fine. Other times it will appear dead and come to
> TIA
PaulHsu
Guest
Posts: n/a
Re: Re: [96 Accord LX] Intermittent Speedometer issue
> sensor is ok
> might be inclined
> message
> > Hello,
> erratically.
> dead and come to
> is a
> other than a
> > TIA
I have an old honda have same problem.
Posted using the http://www.autoforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.autoforumz.com/Honda-96-A...ict105316.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.autoforumz.com/eform.php?p=490476
speedy
Guest
Posts: n/a
The electroinis in the speedo have gone bad. If the sendsor was screwy
you wouldnt gat an odometer reading AND the check engine light would
come on since it does use speed as one of the computers calculations.
-SP
Paul Jackson wrote:
> Hello,
> TIA
RSSHM@hotmail.com
Guest
Posts: n/a
screwy
> -SP
> Paul Jackson wrote:
> > Hello,
erratically.
come
a
is
> > TIA
I had this problem with my '96 Civic. I replaced the speedo unit with
one from a junkyard (found online for $65.) I later had the same
problem with the new unit and it turned out to be a short in the engine
wiring harness near the intake manifold and throttle body. A little
electrical tape and a zip-tie and I was good to go.
yol1260
Guest
Posts: n/a
"RSSHM" wrote:
> was
> screwy
> light would
> calculations.
> > -SP
> > Paul Jackson wrote:
> &nbsp;> > Hello,
> &nbsp;> >
> &nbsp;> > The speedometer on my 96 Accord LX has started to
> behave
> erratically.
> &nbsp;> > Sometimes it will work fine. Other times it will
> appear dead and
> come
> &nbsp;> > to life after the car has been driven a while.
> &nbsp;> > Other times it will start and stop randomly while
> driving.
> &nbsp;> >
> &nbsp;> > The odometer seems to be working fine though.
> &nbsp;> >
> &nbsp;> > Anyone have any idea what could be causing this and
> if this is a
> &nbsp;> > relatively easy fix for a non-mechanic?
> &nbsp;> >
> &nbsp;> > I have the Chiltons book 30152 and I can't find
> anything other than
> a
> &nbsp;> > recommendation to check/replace the speed sensor
> wiring/unit. There
> is
> &nbsp;> > nothing that shows you how to actually *do* it
> though.
> &nbsp;> >
> &nbsp;> > TIA
> unit with
> same
> the engine
> little
The 96’ Accord LX has an Electronic Speed Sensor (VSS) that is located
on the top of the transmission. I think all you need to do is to
replace that sensor. I replaced a used sensor which solved the same
problem that you have it with your car. You need to pay attention to
the very small pin that goes under the sensor, otherwise you lose it.
Good Luck.
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.autoforumz.com/eform.php?p=500374
Michael Pardee
Guest
Posts: n/a
"yol1260" <UseLinkToEmail@AutoForumz.com> wrote in message
news:1_500374_7fccafe572c5eb05bab01d5f04ce10a6@www .autoforumz.com...
> "RSSHM" wrote:
> > was
> > screwy
> > light would
> > calculations.
> > > -SP
> > > Paul Jackson wrote:
> > &nbsp;> > Hello,
> > &nbsp;> >
> > behave
> > erratically.
> > appear dead and
> > come
> > driving.
> > &nbsp;> >
> > &nbsp;> >
> > if this is a
> > &nbsp;> >
> > anything other than
> > a
> > wiring/unit. There
> > is
> > though.
> > &nbsp;> >
> > &nbsp;> > TIA
> > unit with
> > same
> > the engine
> > little
> The 96' Accord LX has an Electronic Speed Sensor (VSS) that is located
> Good Luck.
Although the odometer is driven off the same sensor and it also feeds the
electronic transmission controller. That's what points to it being in the
speedometer electronics... normally a bad solder connection or electrolytic
capacitor.
Mike
Mista Bone
Guest
Posts: n/a
Clean the connector at the VSS sensor first, that cures 99% of the VSS
codes.
I've sold 8-10 VSS senders on here and other forums, about 1/2 didn't help
but the cleaning did. I only asked $20 shipped for a VSS sensor ASSMEBLY
(Civic) which is dirt cheap!
> "RSSHM" wrote:
> > was
> > screwy
> > light would
> > calculations.
> > > -SP
> > > Paul Jackson wrote:
> > &nbsp;> > Hello,
> > &nbsp;> >
> > behave
> > erratically.
> > appear dead and
> > come
> > driving.
> > &nbsp;> >
> > &nbsp;> >
> > if this is a
> > &nbsp;> >
> > anything other than
> > a
> > wiring/unit. There
> > is
> > though.
> > &nbsp;> >
> > &nbsp;> > TIA
> > unit with
> > same
> > the engine
> > little
> Good Luck.
> Topic URL:
http://www.autoforumz.com/Honda-96-A...dometer-issue-
ftopict105316.html
sade001
Oct 15, 2005 09:40 PM
ap
Jul 25, 2005 07:40 PM
sdonn
Jun 18, 2005 10:17 AM
Jun 3, 2005 01:06 AM
Charles Lasitter
May 4, 2005 04:44 PM
