Accord UK '93 - ABS / ALB Light on
Old May 4, 2005 | 11:16 AM
zero
Guest
Posts: n/a
Last of the jap ones
need a shot term bodge here chaps
MOT in 6 weeks so need to stop the bloody light being on
dealership reckon the pump has gone and the bill gave me a heart attack
Q) Is there a way of turning the light off till after the MOT ?
Dont mind putting it back on to be kosher but need the mot to go thru
Thanks
motsco_ _
Guest
Posts: n/a
Re: Accord UK '93 - ABS / ALB Light on
> Thanks
Remove jewlery, reach up behind dash find the right lamp, and remove the
bulb. Your owner's manual will tell you which fuses to try if this isn't
your cup of tea. :-)
'Curly'
dold@XReXXAccor.usenet.us.com
Guest
Posts: n/a
Isn't part of the test verifying that all of the bulbs come on when you
first turn the key on?
Clarence A Dold - Hidden Valley (Lake County) CA USA 38.8,-122.5
Abeness
Guest
Posts: n/a
Not when you want to *disable* the light. ;-)
piperspost@webtv.net
Guest
Posts: n/a
I would not mess with trying to disconnect any fues to turn off that
light, I was told by the dealer that you could do some serious damge to
the rest of the panel.
Guest
Posts: n/a
I meant what the tester will do, not what you want to have happen.
Al Reynolds
Guest
Posts: n/a
> Thanks
AFAICS there are only two possible ways round this.
Method 1
The UK MOT only checks if the light comes on and
goes off again when you turn the car on. They do not
check if the ABS actually works. This means you
have to get the light to do this. One way I can think
of is to wire it in parallel with the SRS bulb, and just
short the ABS bulb connector.
Method 2
Just do what the drivers of all old-bangers do. Ask
around for the dodgiest MOT station in the area. How
likely do you think it is that they will notice no ABS
light if the bulb is "gone"? Not very.
Al
PS Are you selling this car? If so then be very clear
about the state of the vehicle's ABS when you sell the
car, or you could end up in deep trouble if there's an
accident.
motsco_ _
Guest
Posts: n/a
I've reached up in the dash (with the power + lights on) to 'borrow' the
ABS bulb to replace another bulb that went dead. You can feel the rows
of bulbs, and they just rotate a 1/4 turn counter-clockwise to come out.
If you disable the ABS light, they may not even be sure whether your
year / model was supposed to have ABS . . . So they may not pursue it
any further (unless they look under the hood and see the extra plumbing) :-(
I'l bet ABS was optional in '93.
'Curly'
Abeness
Guest
Posts: n/a
Oops. Duh! I was an idiot--your message, now that I reread it, is clear.
Musta had fog in the brain, sorry.
SoCalMike
Guest
Posts: n/a
id take the cluster out, and piggyback a wire/bulb from a different
light (check engine?) to take that spot. that way the ABS light goes on
with the check engine light, and shuts off at the same time.
SoCalMike
Guest
Posts: n/a
>>Thanks
> Method 1
> Method 2
it may be a non-abs model ;)
> Al
> accident.
zero
Guest
Posts: n/a
it was the last of the jap accords in the uk so i think they emptied the
parts bin and fitted everything
abs , cruise control and air con is mega for a UK car of 93 vintage
its only in recent years over here that air con has caught on
"motsco_ _" <"motsco_ _"@interbaun.com> wrote in message
news:42275559.4030102@interbaun.com...
> 'Curly'
zero
Guest
Posts: n/a
Remind me - SRS ?
I know i'll kick myself . . .
"Al Reynolds" <ajr-news@bat400.com> wrote in message
news:d075hj$rbd$1@south.jnrs.ja.net...
> > Thanks
> Method 1
> Method 2
> Al
> accident.
SoCalMike
Guest
Posts: n/a
zero wrote:
> Remind me - SRS ?
Supplemental
Restraint
System
aka: airbag.
zero
Guest
Posts: n/a
no air bag on mine - next model had one
"SoCalMike" <mikein562athotmail@hotmail.com> wrote in message
news:VKmdnZcHireXabHfRVn-qw@comcast.com...
> zero wrote:
> > Remind me - SRS ?
> Supplemental
> Restraint
> System
> aka: airbag.
Oct 12, 2005 02:30 PM
jazzy29
Oct 8, 2005 11:35 AM
lmart
Aug 26, 2005 06:01 AM
PMS
May 22, 2005 10:16 PM
raygold
May 4, 2005 11:16 AM
