CRX Radiator Drain Plug Location
Old May 4, 2005 | 11:16 AM
cacht22
Guest
Posts: n/a
Need help locating radiator drain plug for 1990 CRX.
Would appreciate someone sending back location. Want to flush radiator
and re-fill myself and not a shop.
Thank you
Ned Buckmaster
Guest
Posts: n/a
Re: CRX Radiator Drain Plug Location
Passenger side rear (bottom) of radiator; a white plastic wingnut.
"cacht22" <ebidrob@hotmail.com> wrote in message
news:1110067942.181041.238870@f14g2000cwb.googlegr oups.com...
> Thank you
SoCalMike
Guest
Posts: n/a
>>Thank you
some aftermarket radiators might not have one. in that case, just undo
the bottom hose and let it drain that way.
John Ings
Guest
Posts: n/a
On Sat, 05 Mar 2005 18:50:55 -0800, SoCalMike
That's probably a better way anyhow. The drain plug or white plastic
wingnut thingie is rather small and made of plastic that gets brittle
with age. If backflushing is on the agenda, the large bottom hose
orifice gives better access.
cacht22
Guest
Posts: n/a
thanks for all your posts.
will try it out tomorrow. 179k miles, never changed.
gotta do it.
no sunday afternoon nascar = home/car projects.
jim beam
Guest
Posts: n/a
> gotta do it.
when diluting the antifreeze, make sure you use distilled water, not
stuff out of the faucet - its mineral content accelerates corrosion.
SoCalMike
Guest
Posts: n/a
>> gotta do it.
regular would prolly be ok to do the flush with, tho.
Mister Coffee
Mar 14, 2024 03:23 PM
rossftn
37
Aug 29, 2016 09:06 PM
thedeadpoet000
Feb 27, 2013 08:14 PM
Abeness
Aug 4, 2005 09:34 AM
butch burton
May 18, 2005 11:20 PM
