changing belts on honda passport
Guest
Posts: n/a
Re: changing belts on honda passport
bruiser81 wrote:
> In stupidity i decided to change my own belts and it went ok but when i
> crank my truck now it smokes a lil bit and you can smell burning rubber
> anyone got any ideas why
They're just too loose. They have to be VERY tight, compared to the kind
on cars from twenty years ago.
'Curly'
'Curly'
Guest
Posts: n/a
My guess would be that they're too tight. The OP didn't mention if
there was any squealing or not. In my experience too tight doesn't have
any immediate symptoms but can lead to loud pump bearings after a
while. While loose belts tend to squeal.
What happens after you're done cranking? Does it quit? Does it even
start? In either case, need more info and you're belts are misadjusted
(whether tight or loose).
- Justin
- Justin
Pete from Boston
Sep 1, 2005 06:30 PM
