How to replace the light bulbs behind the dashboard?
Old May 4, 2005 | 11:16 AM
Arctic Wolf
Guest
Posts: n/a
I have a 2001 Honda Civic LX 2 door coupe.
There are three dials next to the radio.
Mode Control Dial
Temperature Control Dial
Fan Control Dial
When the headlights are turned on, the three dials light up (nomally).
However, now, the Temperature Control Dial is half lit, and the
Fan Control Dial is not lit at all. The Mode Control Dial is fully lit
as usual. My assumption is that there are two light bulbs for these
three dials, and the bottom bulb is broken.
Can I replace the light bulb myself without too much trouble,
or does this need to be taken into the shop?
halo2 guy
Guest
Posts: n/a
Re: How to replace the light bulbs behind the dashboard?
you just have to remove the outside trim piece and you should be able to go
to the auto parts store for a new bulb.
"Arctic Wolf" <ArcticWolf@mail.com> wrote in message
news:Dv6Yd.691$qW.663@newsread3.news.atl.earthlink .net...
> Mode Control Dial
> Fan Control Dial
motsco_ _
Guest
Posts: n/a
> Mode Control Dial
> Fan Control Dial
Do a google search for the pdf (or otherwise) instructions for removing
the stereo. You'll see that the part you're after is exposed in the
procedure. Look at the bulb at the dealer, then see if you can find them
at NAPA or Canadian Tire, or whatever. It will be 1/5th the price if
it's the little bulb that looks like the tip of a thermometer.
'Curly'
der Mond
Dec 13, 2024 06:34 PM
Metadata
Oct 4, 2018 03:05 AM
Getzbie
Dec 31, 2013 01:22 PM
jdserrano
Jul 27, 2012 12:13 AM
James Rose
Jun 28, 2005 04:20 AM
