MSN Dashhawk
Old Jun 6, 2007 | 12:24 PM
Endless's Avatar
MSN Dashhawk
MSD has just come out with a new scangauge-type device called the Dashhawk. It's $300 and I'm still trying to figure out if it is compatible with the Fit, but I wanted to post it here to let everyone know about it.
DashHawk Vehicle Information Display
Old Jun 6, 2007 | 02:37 PM
WhatFreshHell's Avatar
I am nowhere near my car, but this is from the site:
My vehicle is not on the supported list. Is it CAN compliant?
If you vehicle is not listed in the supported vehicles page, all is not lost! There are many vehicles being added/tested every day and it is hard to capture them all and keep them up to date, so a good way to see if your car has a CAN bus is the following:
  1. Locate the OBDII connector. It is under the dash on the driver’s side of the vehicle, often either under the steering wheel or tucked up next to the driver’s side kick panel.
  2. Look carefully at the plug with a flash light or other bright light source. If pins 6 and 14 have metal pins in them (i.e. are “populated”) then the vehicle has a CAN bus and DashHawk will most likely work with this vehicle.
Old Jun 6, 2007 | 02:51 PM
kps's Avatar
kps
Honda Fit Forums Moderator
The Fit uses CAN.
Old Jun 6, 2007 | 05:41 PM
Illusive's Avatar
oooo so what are your guys' impression regarding this unit? Wonder if it is worth it...
Old Jun 6, 2007 | 06:15 PM
Endless's Avatar
Originally Posted by kps
The Fit uses CAN.
Cool, I was going to check this out today afterwork.
User1
Jun 12, 2019 12:56 PM
fitchet
Jun 12, 2013 04:31 PM
Brain Champagne
Feb 7, 2011 11:38 PM
s0x
Jan 25, 2008 02:33 AM
fits_all
Jan 10, 2007 12:41 PM
