Cleaning Accord engine compartment (places to avoid getting water?)
Old May 4, 2005 | 11:16 AM
techman41973@yahoo.com
Guest
Posts: n/a
I plan on cleaning the engine compartment of my 97 accord with 137,000
miles. I know to cover the alternator and obvious electrical
connectors. I also hear advice to cover the distributor, but from my
what I recall Honda 2.2 vtec engines are distributorless. Are there any
other parts of the engine compartment that I should be extra carefull
to keep water away from?
I plan to use Simple green, a low-pressure mist, a cold engine when
cleaning and to final rinse with distilled water.
Many have talked about what possibly can go wrong.
I would like to especially hear from others where something DID go
wrong when they cleaned under the hood and what they would have done
differently. Thanks
SadaYama
Guest
Posts: n/a
Re: Cleaning Accord engine compartment (places to avoid getting water?)
Do you mean there is no distrubutor cap and rotor and spark plugs? and
wires and coil wire??
All you need to do is cover all electrical wires and stuff with a
plastic sheet. Get a engine Gunk Cleaner can, and spray all over; wait
for 5-10mins and clean with water. Distilled water may be a overkill.
Make sure you do not start the car for 30mins. After cleaning, I also
spray a can of WD40, on all rubber parts and hoses for protection and
long lasting elasticity. Make sure you don't spray WD40 on belts.
jim beam
Guest
Posts: n/a
please DO NOT spray wd40 on natural rubber - it rots it.
do_not_spam_me@my-deja.com
Guest
Posts: n/a
> accord with 137,000 miles. I know to cover the alternator
> and obvious electrical connectors. I also hear advice to
> cover the distributor, but from my what I recall Honda
> 2.2 vtec engines are distributorless. Are there any other
> carefull to keep water away from?
> engine when cleaning and to final rinse with distilled water.
The fact you'll be avoiding high-pressure water almost guarantees
you'll stay out of trouble.
Do not apply WD-40 to any rubber or plastic since it's almost like
mineral spirits and can attack them, especially the water hoses, whose
EDPM rubber (also used for weatherstrips) is impervious to almost
everything except oils. Silicone oil (spray lube, many vinyl/rubber
protectants) is an exception, keep silicone from getting sucked into
the engine, such as through the intake or a vacuum leak (loose hose)
because it can ruin oxygen sensors. Actually EDPM rubber doesn't need
silicone oil because it's virtually impervious to UV rays and ozone.,
unlike vacuum, fuel, and brake hoses.
q45yesman
Guest
Posts: n/a
> keep silicone oil from getting sucked into the engine
Wouldn't bearings also likely be damaged from a detergent solution?
For example, alternator bearings, electric fan bearings (if any), etc.
Also, what about mechanical fuel pumps (if equipped)?
They may have an air inlet hole, often on the upper half, which might
allow potentially damaging wash fluids to drip onto the pliable
diaphragm.
SadaYama
Guest
Posts: n/a
<<<<<<<< After cleaning, I also spray a can of WD40, on all rubber
parts and hoses for protection and long lasting elasticity. Make sure
you don't spray WD40 on belts. >>>>>>
Oops, I am very SORRY !!! about spraying with WD40. What I meant was
SILICONE SPRAY and not WD40. Thanks for the correction GUYS !
jim beam
Guest
Posts: n/a
that's a great point! many is the time i've seen pressure washing ruin
bearings, seals, paint, contaminate brake fluid, etc.
camerakid22
Nov 22, 2016 07:24 PM
Soon2015FitWillBeMine
Jun 17, 2015 09:52 AM
tin
Dec 1, 2009 06:12 PM
coralaholic
Sep 18, 2009 11:37 PM
sLiVeRwOrM
May 14, 2007 09:08 PM
