Eibach Pro Kit problems
Old Jun 15, 2007 | 06:20 PM
davinabretina's Avatar
Hey, all you Eibach fans -- I got a few problems and could use your assistance.
I installed the Eiback Pro Kit on my 2007 Fit and the ride sucks! Have you ever seen a car where you know the guy cut the springs cuz it rocks, front to back, when it hits a bump? Well, that's how my car rides now. It's like the spring rates are different, front to back. Also, the springs in the rear make a 'sproing' sound when I drive over something like a speedbump, one wheel at a time.
So, here's what I'm wondering--should I be able to read the stamped 'Eibach' on the side of the springs when installed? What's the top and bottom of the springs? Should the tightly wound, dead coils in the rear be at the top or bottom?
Help!!
Old Jun 15, 2007 | 06:43 PM
JDMchris.com's Avatar
I run THIS
the eibach should be rightside up, thats all. The fits wheelbase is small so there is alot of rocking front to back. as far as the noise, i know the tein and the tanabe come with a rubberthat wraps around the coil to prevent the noise. Im sure you can make your own from stuff at autozone.
Old Jun 15, 2007 | 07:54 PM
smeister's Avatar
Just make sure the writing on the Eibachs are right side up when you installed them. JUST INCASE you missed that. My Eibach springs squeak sometimes. I think its cause of that rubber hose around the rear springs.
Old Jun 16, 2007 | 04:05 AM
quangalang's Avatar
did you cut the bump stops in half? that could be your problem for the bouncy ride
Old Jun 16, 2007 | 08:02 AM
Thanks for the quick replies.
The rear springs came with a clear plastic piece wrapped around 3 of the coils - I assumed for noise.
I did cut 30mm from all of the bump stops per Eibach's instructions - mistake??
Sounds like the Eibach's accentuate the bounce because of the short wheelbase, but I didn't have that problem with my 2006 Scion XA...
Old Jun 17, 2007 | 01:24 AM
jeffquach's Avatar
springs need to settle...i had noise for the first 1-3 days when i got mine installed.
Old Mar 24, 2008 | 02:29 AM
t3chn0rav3rb0y's Avatar
woo hoo jeez im going through the same thing and its been freaking me out lol... i also have a strange noise from the front... sounds like my sway bar is going to vibrate off... anyone know what it could be???
Old Mar 24, 2008 | 05:54 AM
SPON FIT's Avatar
loose endlink?
KIRK!
Jun 30, 2013 01:03 PM
Pneuma
Oct 5, 2012 11:57 PM
SNOW
Feb 10, 2009 08:03 PM
Jimmy101
Aug 29, 2006 03:07 PM
