'05 Accord EX - Poor FM reception
Old May 4, 2005 | 04:44 PM
Imminent Vengeance
Guest
Posts: n/a
Re: '05 Accord EX - Poor FM reception
Mike W wrote:
> I have the same problem with my 2004. I really believe the radio is OK, its
> the antenna. GM tried that "invisible" antenna in the windshield quite a
> few years back and I never liked it either. Nice for looks, lousy for
> reception.
My grandfather has a 2003 Ford Crown Victoria with the antenna in the rear
window as well. I don't know how well it works though. As for the GM
experiment, my father had an '80 Chevy Malibu with the windshield antenna,
but the radio was only AM. I don't remember if AM/FM radios from that
period used the same antenna or a typical one.
Howard Lester
Guest
Posts: n/a
"Dick" wrote
> >The stock FM radio can't deal with multipath. The radio might work
> >great out in the middle of nowhere but it's garbled and fuzzy sounding
> >in a city.
> Phoenix, the 5th largest city in the U.S., is not exactly out in the
> middle of nowhere. I don't see any multipath problems with our radio
> when driving around Phoenix.
Nor with mine when driving in Tucson.
Dick
Guest
Posts: n/a
On Thu, 07 Apr 2005 22:02:00 -0700, Kevin McMurtrie
<mcmurtri@dslextreme.com> wrote:
>> The subject line is about FM reception, so I found numerous Phoenix stations
>> on FM as well on this radio. As characteristic of FM, different spots along
>> the drive yielded signals for better or worse; occasionally quite strong. I
>> think it's a fine radio, and I am surprised at how good its reception is
>> considering the in-the-glass antenna. I expected a lot worse. Oh, and the
>> audio quality is great, too, but I know that's a matter of opinion. ;)
>> Howard
>in a city.
Kevin McMurtrie
Guest
Posts: n/a
In article <d33h5e$jhc$1@onion.ccit.arizona.edu>,
"Howard Lester" <hlester@mmto.org> wrote:
> "Dick" wrote
> > I have not seen that problem in our 2003 EX with Nav. In fact, the
> > radio has more sensitivity on both AM and FM than the one in our Jeep
> > Grand Cherokee with its telescoping outside antenna. I regularly
> > listen to AM stations 100 miles away. I can also pick up our local FM
> > music station more than 100 miles away with a good signal. As an
> > amateur radio operator, receiver sensitivity is an issue with me. I'm
> > very happy with this radio.
> Also an amateur radio operator, I had to take the "EX Challenge" this
> morning. Mine's an '04 EX auto 4-cyl non-Nav, non-leather. It's the stock
> 6-CD changer. I live in southern Arizona. My radio works great: at 7AM
> (about an hour after sunrise) I was listening to KSL in Salt Lake City, Las
> Vegas, KFI in L.A., and could have gotten KNBR in SF if we didn't have a
> local station at 690. I was also getting strong signals from numerous
> Phoenix stations 100+ miles away, and FWIW there is a mountain range close
> by that is "in the way." I could be doing some serious broadcast band
> DX'ing with this radio.
> Howard
in a city.
Howard Lester
Guest
Posts: n/a
"Dick" wrote
> I happen to live in north/central Arizona. Maybe radios just work
> better in Arizona? :-)
It's the thin air... ;)
N7SO
Dick
Guest
Posts: n/a
On Thu, 7 Apr 2005 07:47:10 -0700, "Howard Lester" <hlester@mmto.org>
>Howard
Dick
I'm_a_dreamer
Guest
Posts: n/a
>>If you are in a tunnel for more than a few seconds and don't lose
signal, it is because you're driving in an area served by a local
repeater.
The radios buffer a few seconds' content internally, and XM's two
satellites send the same signal a few seconds apart. All this together
gives you a reasonable chance of maintaining a signal when driving
under an overpass for example. <<
Thanks for the explanation.
Howard Lester
Guest
Posts: n/a
Howard
frontmed@gmail.com
Guest
Posts: n/a
repeater.
I'm_a_dreamer
Guest
Posts: n/a
I just purchased a new Accord EX and have noticed I get very poor FM
reception. It doesn't want to hold a station at all. I get a lot of FM
station drift even with strong signals and on flat terrain. Has anyone
else experienced this?
Where is the antenna located? Does it need to be raised?
I'm_a_dreamer
Guest
Posts: n/a
Yeah, it's pretty nice, no station drift at all and no commercials, and
100+ channels. $12.95/mo isn't bad, but I wonder if they are going to
keep raising it year after year, probably.
I wonder why the antenna picks up XM so good? Maybe because it's a much
stronger signal coming from directly overhead, but then why don't I
lose it in a tunnel?? Anyone know the electronics of it??
Dick
Guest
Posts: n/a
On 6 Apr 2005 10:43:09 -0700, "I'm_a_dreamer" <im_a_dreemer@yahoo.com>
wrote:
>Looks like I'll have to subscribe to XM radio.
That would sure solve your problem. And you already have the radio.
I'm_a_dreamer
Guest
Posts: n/a
halo2 guy
Guest
Posts: n/a
my girlfriends 04 Accord is the same way.
You can put in another stereo system but you will have to leave the
original. The stereo can be mounted in the armrest or glove compartment
etc. I would take it to a custom install place and see what they say.
"Kevin McMurtrie" <mcmurtri@dslextreme.com> wrote in message
news:mcmurtri-98B115.22254805042005@corp-radius.supernews.com...
> In article <1112720197.994443.256430@o13g2000cwo.googlegroups .com>,
> Same here. I got the 05 Accord Hybrid and am pissed to find that its
> cheap stereo is not replaceable. Climate control and low frequency
> noise cancellation are integrated. FM stations that I used to get
> perfectly clearly in my previous car are unintelligible now. I replaced
> the tinfoil speakers (you can literally crush them in your hand) in the
> rear deck but it seems that the system only puts out a few watts per
> channel.
> I do not find the radio acceptable at all. I need to contact the
> dealership to see WTF is up with this. It's a $30K car that CAN'T have
> a decent radio.
Dick
Guest
Posts: n/a
On Wed, 06 Apr 2005 11:41:52 GMT, "Mike W" <mwolfer@verizon.net>
>reception.
Mike W
Guest
Posts: n/a
reception.
> channel.
> a decent radio.
Kevin McMurtrie
Guest
Posts: n/a
channel.
a decent radio.
halo2 guy
Guest
Posts: n/a
it is typical of these Hondas. The antenna is built in to the rear window.
There is not modifying you can do. Perhaps an amplifier might work but that
might just amplify the noise.
"I'm_a_dreamer" <im_a_dreemer@yahoo.com> wrote in message
news:1112720197.994443.256430@o13g2000cwo.googlegr oups.com...
bach
Jul 26, 2015 08:29 PM
Occam
Sep 28, 2010 09:58 AM
李克勤
Nov 20, 2008 11:57 AM
Frank
Oct 16, 2005 09:30 PM
Frank
Sep 11, 2005 10:32 PM
