93 Honda Civic
Old May 4, 2005 | 04:44 PM
enravi
Guest
Posts: n/a
93 Honda Civic
I have a 93 Honda civic. The temperature meter stays at the regular
positions for some time and then moves very fast to the highest level. It
happens especially when I drive on highways. What is causing this?
thermostat or cooling system or any other problem? Please help!!
Thanks
Enr
TeGGer®
Guest
Posts: n/a
Re: 93 Honda Civic
"enravi" <enravi@yahoo.com> wrote in
news:13b98236419c18da31383b7d0104e2ba@localhost.ta lkaboutautos.com:
Need more detail: How long on the highway before it starts to overheat?
Happens every time? When the needle starts movng up, does it go back down
if you turn your interior heater on full blast?
Four possibilites right now:
1) Bad thermostat
2) Bad rad cap
3) Blocked rad
4) Fins on rad corroded and falling off.
TeGGeR®
www.tegger.com/hondafaq/
Randolph
Guest
Posts: n/a
Re: 93 Honda Civic
First of all, don't drive the car until this is fixed. You don't want
the head to warp or crack.
If the engine overheats at highway speeds, the most likely cause is a
failed water pump. Regardless, replace the thermostat first, as it is
much cheaper and easier to do.
danielle1432
Oct 10, 2005 12:36 PM
Tinob
Aug 25, 2005 11:03 AM
nick.sideshow@gmail.com
May 22, 2005 10:16 PM
KWW
May 4, 2005 11:16 AM
Scott Miller
