MT fit jerking at 1st gear
Old Aug 27, 2007 | 04:44 AM
darrell's Avatar
is it just me or are any other fit require an extremely focus mind and feet to do a smooth acceleration? and some times even when the clutch is fully engaged at 2500-3000 RPM then i continue holding in the gas to do a low-mid acceleration, the car would just jerks . well I've been driving manual all my life and i consider myself an above advage driver. I've never owned a MT car that act the way fit does. is it because of the gutless engine? (all my previous/second car has 6 or more cylinders and would not jerk on 1st.) i work at a shop and I've driven a fair amount of cars but there is nothing else like the fit. I'm thinking it might be something with the drive by wire acting up..... i don't know. it pisses me off so usually i would just floor it to take away the jerking which defeated the purpose of driving a econo box to save gas. oh, and friends who've driven my car says the same thing. so it's not just me.
Old Aug 27, 2007 | 05:16 AM
blackgd3's Avatar
Senior Member
It's definitely caused by the engine's lack of torque. You just have to get used to feathering the clutch
Old Aug 27, 2007 | 07:07 AM
phil_qc's Avatar
I'm with you guys... The worst is the 1st when cold,
now you talk about jerking ! The good and the bad
news is that it's how this car is made... need to rev
high to got torque. It's a Honda thing...
Philippe
Old Aug 27, 2007 | 11:27 AM
doctordoom's Avatar
Supervillain
i agree with the above posters, same thing happens to me too. it just took some changes in the way i drove, now it's not a problem anymore.
Old Aug 27, 2007 | 01:34 PM
kptrulee's Avatar
It got some getting used to when the engine was cold but once it got to operation temps, it felt fine to me.
Old Aug 27, 2007 | 01:52 PM
JDMchris.com's Avatar
I run THIS
i only notice this when the AC is on.
Old Aug 27, 2007 | 01:55 PM
Darkcambria's Avatar
I notice it a lot when switching from driving my '89 Accord to my Fit. They drive quite differently but after a little bit you just adjust.
Old Aug 27, 2007 | 06:20 PM
Spule 4's Avatar
Exactly, MUCH worse then.
I kind of agree on the lack of HP/torque, but I have driven cars with less HP (28 and up) and did not have this problem.
What seems to happen, you rev, let up on the clutch, the car moves forward, and falls on its face..(lurch)..then catches.
I still think the idle is too low with the air on at idle, it should kick up a bit to lessen this effect?
Old Aug 28, 2007 | 12:42 AM
darrell's Avatar
^exactly what you said. it feels like as soon as the clutch engaged and you think you gonna move along smoothly, the car automatically cuts off your throttle and go again(X3 times when cold). that's why i think it's they way the programed the throttle to cause such problem. I've driven less power full car such as 1.3 echo with wired throttle and it didn't have this problem and maybe I'm just too used to making small adjustments with my feet to make a car moves smoothly without the aid of drive by wire computer. and when i do those adjustment with my feet the computer doesn't know how to response to the input.... or maybe just lag of torque
seriously, my 82 carbriolate with 250000 km on clock + no oil change for a year pulls harder than the fit. lol
Old Mar 4, 2008 | 12:12 AM
goodyonsen's Avatar
ive had no problems with my m/t fit, its my first car and my first m/t. for me, there is hardy any jerking or shaking or whatevers in first gear.
Old Mar 4, 2008 | 12:22 AM
i think you guys are either not clutch-in all the way or clutching out
too soon.
although the full engagement is around the middle of the clutch pedal's
throw, it starts engaging pretty low near the floor.
Old Mar 4, 2008 | 02:57 AM
Firebat666's Avatar
i notice the same thing.... ur not alone!
Old Mar 4, 2008 | 04:15 AM
storm88000's Avatar
Frequent FitFreak Poster
Yep. The surge in 1st/2nd/3rd gear in the Fit when the engine is cold is one of the only negative things I've noticed.
Old Mar 4, 2008 | 11:21 PM
CorrodesTheFilm's Avatar
I think a lot of it might have to do with the fact that the Fit's first gear is low low low. I guess it's necessary to get the car moving from a stop with so little torque, but I try to shift into 2nd as soon as possible, and even use 2nd when driving around parking lots, etc.
Old Mar 5, 2008 | 01:14 AM
pcs0snq's Avatar
After moving :
It's not the Clutch
It's not the nice 5 speed
It's the poorly designed Throttle by wire that is the cause of making it hard to shift.
With a normal design, when you lift off the gas the RPM's will drop and fall right into a spot for the next gear. With the Fit's TBW, the rpms will stay high and even pop up a tad before falling. 99% of the time, when you release the clutch the eng and tranny RPM are far enough from each other the car will lurch.
Watch the tach and start adding some delay to you time wit the clutch it and that will help.
Old Mar 6, 2008 | 02:07 PM
dihydroxide's Avatar
The first gear definitely jerks. Places I notice this problem:
1) Starts - solve by engaging at higher rev and ease the clutch in
2) Speed bumps - solve by disengaging clutch while going over the hump
3) Bumper to bumper traffic where I'm engine breaking - solve by being in second gear or not taking right foot off the gas completely
Hope this helps.
Old Mar 6, 2008 | 02:12 PM
Originally Posted by pcs0snq
After moving :
It's not the Clutch
I agree. I think the bad Drive by Wire system is the culprit and not the low torque issue. But, I don't think the OP was talking about the hanging rev during shifts... he's talking about the jerk in first gear at low revs.
Old Mar 8, 2008 | 08:40 PM
richard612's Avatar
I don't know about a jerk, but I have noticed a clutch shudder when cold in 1st gear. While the clutch is in the "friction zone," there's a rapid grab-slip-grab that feels like a warped clutch disc. It goes away as soon as the car warms a bit.
Old Mar 8, 2008 | 09:29 PM
IstayFitted's Avatar
I've notice the same feeling in my fit...could anyone shed light on the issue?
Old Mar 9, 2008 | 12:08 AM
C_O's Avatar
C_O
Senior Member
odd.. in 1st gear i'm experiencing absolutely no jerking. i roll out of 1st gear lower than 400rpm sometimes and have not stalled. i can't imagine jumping out of 1st at 3k+ rpm, maybe that's the problem? i usually wait till the cold light goes out before i leave, cold engine/tranny may also be the cause of the jerky 1st gear.
-Charlie
