Camber kit question
Old Sep 4, 2007 | 06:15 PM
Jap 07 Fit's Avatar
Camber kit question
i have an 07 fit with a slight tire wear problem but only in the front..the car is lowered on T1R v2 springs....anyone know where i can buy a good camber kit for the front all help will be greatly appreciated....thanks fellow fit owners.....
Old Sep 5, 2007 | 12:16 AM
spoonek4's Avatar
Tire wear on the outside or the inside?
Old Sep 5, 2007 | 01:05 AM
CarDemon's Avatar
Senior Member
did you have a 4 wheel alignment after the drop spring install and few weeks of settling?......just curious
Old Sep 5, 2007 | 04:00 AM
claymore's Avatar
No camber kits available. There are bolts that allow a minimal amount of camber adjustment. Either live with the worn out tires every few months or put it back to stock.
Old Sep 5, 2007 | 03:39 PM
rinsk's Avatar
does the same thing happen with gf210's? i plan on having my new wheels and springs put on at once, and the having everything realigned. does anybody think there would be problems? same diameter tire as stock.
Old Sep 6, 2007 | 02:03 AM
claymore's Avatar
Maybe if you searched you may have found THE GIANT STICKY https://www.fitfreak.net/forums/fit-...ons-specs.html
to answer the same question.
Or even this STICKY for the second question.
https://www.fitfreak.net/forums/fit-...s-answers.html
Old Sep 6, 2007 | 09:33 AM
spoonek4's Avatar
And here is the alignment reading after I got my car lowered with T1R ver1 springs and installed SPC front camber bolts...
https://www.fitfreak.net/forums/fit-...d-today-2.html
These bolts are cheap so I would suggest u to install springs & the bolts then have alignment done after. Always remember u will still worn out your tires on the outside edges if u dial the camber as close to 0 degree as possible, coz u don't drive straight alllllllllll the time.
Tire rotation is very important too........
Old Sep 11, 2007 | 04:43 PM
Jap 07 Fit's Avatar
yeah tire wear is on the inside of the tire.... ima look into the camber bolts...and for aligning the car i haven't done so..i will be doing so after the camber bolts thanks guys for all the info...highly appreciated...
Old Sep 16, 2007 | 02:41 PM
HONDAMATIC's Avatar
bad toe is what will really kill your tires, after i put my df210s on, the toe went off pretty bad, the camber not so much, was actually still in spec..
Old Sep 16, 2007 | 03:07 PM
743power's Avatar
hah, thats the most retarded thing I have seen on this site in awhile.
Set your toe to zero and enjoy even wearing tires even with the camber.
mac strut cars need a good bit of static negative camber to handle decent anyway
Old Sep 17, 2007 | 04:14 AM
claymore's Avatar
"Set your toe to zero and enjoy even wearing tires even with the camber.
mac strut cars need a good bit of static negative camber to handle decent anyway"
You have never aligned any cars for a living or you would know that only "Internet experts" think toe is harder on tires than camber.
Old Sep 17, 2007 | 06:50 PM
743power's Avatar
hah, not for a living but I have aligned my track car on a hunter rack multiple times.
I have been running -2.5* camber and 0in toe on that car, a double wishbone car that has more camber gain in corners than the fit, and my tires are worn perfectly across, maybe a little chunked on the outside after a track day.
I have had that basic alignment setup for 75,000 miles and 4 sets of tires (2 track tires, 1 snow tires, 1 allseason) and I have not had abnormal or uneven wear on any of them.
I have had this same experience on cars of friends that I have had a hand in setting up.
Old Sep 19, 2007 | 10:08 PM
Fit Ippo's Avatar
Actually for the front you can use camber bolts from the civic and it can give you adjustment all the way from -1.7
Green karma
19
Jan 8, 2013 11:53 AM
hondahazard
Nov 30, 2012 06:31 PM
Santiad
Aug 31, 2011 10:18 AM
JCrimson
Jun 17, 2009 09:57 AM
kodo
May 26, 2008 04:21 PM
