97 EX OBD Readiness
Old May 4, 2005 | 04:44 PM
matt.stern@gmail.com
Guest
Posts: n/a
97 EX OBD Readiness
I am attempting to get my 97 Civic EX inspected at a NJ State Facility.
However, they cannot access my system (i.e. OBD Not Ready for all of
the sensors). My check engine light is NOT on. Following advice I have
done the following: driven the car more (100's of miles); let the car
warm up for 30 min before inspection; disconnected battery and drove
the car for another 100's of miles. Nothing has worked. Any advice
would be greatly appreciated. Thanks.
Frustrated Civic Owner
TeGGeR®
Guest
Posts: n/a
Re: 97 EX OBD Readiness
matt.stern@gmail.com wrote in
news:1114454179.003286.40180@l41g2000cwc.googlegro ups.com:
Have you contacted your local dealer? There may be a TSB on this.
Sometimes reflashing the computer with later firmware will fix this.
More info:
http://www.autotap.com/articles/OBDI...s_Testing.html
This link gives the correct drive sequence for setting ALL the flags that
you have. Your 30-minute drive may not be enough to set ALL the flags that
can be set, and disconnecting the battery may have been the *worst* thing
you could have done.
And:
http://www.gatewaycleanair.com/mecha...r5_6/obdii.htm
An excerpt from the above:
"One of the EPA’s requirements for using a plug-in OBDII check in lieu of a
tailpipe test is to make sure the OBDII system is ready and has run its
system monitors. Some vehicles (mostly some import models) have readiness
issues when it comes to setting all the OBDII monitors. Consequently, the
EPA currently allows up to two readiness flags not to be set prior to
testing 1996 to 2000 model year vehicles."
Are they allowing you two "not-ready" flags?
TeGGeR®
www.tegger.com/hondafaq/
Guest
Posts: n/a
I have contacted my local dealer; they were the ones who suggested
driving the car for 30 min. As far disconnecting the battery
(Inspection Agencie's suggestion), any problem that would have caused
"not-ready" issues had plenty of drive time to be displayed. I believe
NJ checks for three "not-ready" flags. On my car all three are
"not-ready". I read the Autotap link and it seems that I have tried
everything they suggest.
Still frustrated civic owner
TeGGeR®
Guest
Posts: n/a
news:1114460815.155962.288910@f14g2000cwb.googlegr oups.com:
The dealership is incorrect.
Actually, no. See the PDF below.
Excerpt:
"WHAT CAUSES A "NOT-READY" REPORT?
Causes of a "not ready" report:
* Recent vehicle repairs in which diagnostic trouble codes have been
cleared with a OBDII scan tool; or,
* if the battery had been recently disconnected or replaced; or,
* if the vehicle's computer requires a software update; or,
* a pending problem has not yet illuminated the "check engine" light.
> I believe
A generic drive cycle, from NY's DMV:
( http://www.nydmv.state.ny.us/broch/c114.pdf )
"GENERIC DRIVE CYCLE
The purpose of the OBDII drive cycle is to run your vehicle's onboard
diagnostics. This, in turn, allows monitors to operate and detect potential
malfunctions of your vehicle's emission system.
"The correct drive cycle for your vehicle can vary greatly, depending on
the vehicle model and the monitors that need to be reset. When a specific
drive cycle is not known, or drive cycle information is not available from
an OWNER'S MANUAL, the generic cycle described below may assist with
resetting your vehicle's monitors.
"However, this generic cycle may not work for all vehicles. IMPORTANT: If
you choose to use the generic drive cycle below, you must obey all traffic
laws and drive in a safe manner.
"1. The OBDII drive cycle begins with a cold start (coolant temperature
below 122 degrees F and the coolant and air temperature sensors within 11
degrees of each other).
2. The ignition key must not be left on prior to the cold start - otherwise
the heated oxygen sensor diagnostic may not run.
* As soon as the engine starts, idle the engine in drive for two and one-
half minutes, with the air conditioning (A/C) and rear defrost turned on,
if equipped.
* Turn the A/C and rear defrost off, and accelerate to 55 mph under
moderate, constant acceleration. Hold at a steady speed of 55 mph for
three minutes.
* Decelerate (coast down) to 20 mph without braking (or depressing the
clutch for manual transmissions).
* Accelerate again back to 55 to 60 mph.
* Hold at a steady speed of 55 to 60 mph for five minutes. Decelerate
(coast down) to a stop without braking."
Other NYS information:
http://www.nydmv.state.ny.us/vehsafe.htm#einspect
TeGGeR®
curiousity1@gmail.com
Guest
Posts: n/a
MAKE FAST MONEY WITH PAYPAL - ONLY NEED $5
Subject: Make Money Fast Using Paypal Author: Joe Date: 11/20/2004
7:29:50 PM MAKE UNLIMITED MONEY USING PAYPAL!!! You only need $3.00.
Can you really make money so easily? YES... it is logical how you can
earn money through paypal. I found articles with OPRAH WINFREY and an
article published in the Wall Street Journal on 6/16/2001 that explains
how it works. As a member of PayPal, I had already experienced their
efficiency and excellent standing. PayPal is the simplest method of
making and receiving payments online anyone has ever seen! Anyone with
an email address can join, for FREE! You can complete this whole
process in less than one hour. Everything is done on the Internet by
E-mail. It is NOT considered SPAM, so it's perfectly legal! Anyway, it
said that you send money though paypal to each of the emails stated in
the article. You then place your own email address in the bottom of the
list at #6, and post the article in at least 200 newsgroups. (There are
thousands it really isn't hard..try it this is where people usually
stop and miss out) No catch, that was it. It follows the same
regulations as the mailed chain letters, which according to the U.S.
Post Office (1-800- 725- 2161) is indeed legal! Then I invested the
measly $5.00. Well GUESS WHAT!!?. Within 7 days, I started getting
money in my PayPal account! I was shocked! I figured it would end soon,
but the money just kept coming in. In my first week, I made about
$20.00. By the end second week I had made a total over $1,200.00! In
the third week I had over $10,000.00 and it's still growing. This is
now my fourth week and I have made a total of just over $36,000.00 and
it's still coming in rapidly. Its Certainly worth $5.00., I have spent
more than that on the lottery!! : Let me tell you how this works and
most importantly, why it works? REQUIREMENTS: You must have a verified
PayPal account. If you do not have an account you can go to
www.paypal.com and follow the instructions to set up a free account. In
order to place the initial $6 into your account, you will have to
verify your bank account with PayPal (which may take a few days). Or if
you want to start right away, use your credit or debit card to make the
$6 deposit to Paypal. Paypal guarantees your security when using
personal information. They do not release your information to third
parties. Very, very, very, secure! Paypal is 100% secure and is used my
millions of people world wide. STEP 1: Send, though PayPal, $1.00 to
each email on the below list. Make the subject of the payment "Email
List" and in the comments, write "PLEASE PUT ME ON YOUR EMAIL LIST."
What you are doing is creating a service by this and best of all you
are not giving your address to anyone you do not know. THIS IS
ABSOLUTELY LEGAL! The E-mail list: #1)lodge124@bellsouth.net
#2)stephse...@yahoo.com #3) paperclip...@hotmail.com #4 )
ingomanba...@yahoo.com #5)
carney1...@yahoo.com. #6) Lovegirlka...@aol.com STEP 2: Now take the
#1 email off the list that
you see above, move the other addresses up (6 becomes 5, 5 becomes 4,
etc?.) and add YOUR email address (the one used on the paypal account)
as number 6 on the list. STEP 3: Change anything you need to, but try
to keep this article as close to original as possible. Now, post your
amended article to at least 200 newsgroups, message board. (I think
there are close to 32,000 groups) All you need is 200, but remember,
the more you post, the more money you make - as well as everyone else
on the list! ---- DIRECTIONS----HOW TO POST TO NEWSGROUPS, MESSAGE
BOARD---------- Step 1) You do not need to re- type this entire letter
to do your own posting. Simply put your cursor at the beginning of this
letter and drag your : Cursor to the bottom of this document, and
select 'copy' from the edit menu. This will copy the entire letter into
the computer memory. Step 2) Open a blank 'notepad' file and place your
cursor at the top of the blank page. From the 'edit' menu select
'paste'. This will paste a copy of the letter into notepad so that you
can add your name to the list. Step 3) save your new notepad file as a
..txt file. If you want to do your postings in different sittings,
you'll always have this file to go back to. : Step 4) Use Netscape or
Internet explorer and try searching for various newsgroups (on-line
forums, message boards, chat sites, discussions.) Just example you log
on any search engine like yahoo.com, google.com, altavista.com,
excite.com then you search with this subject ? millionaire message
board? or ? money making message board? or ? employment message board?
or ? money making discussions? or ? money making forum? or ?business
message board? etc. You will find thousand & thousand message board.
Click one by one then you will find the option post a new message. :
Step 5) Visit these message boards and post this article as a new
message by highlighting the text of this letter and selecting paste
from the edit menu. Fill in the Subject, this will be the header that
everyone sees as they scroll through the list of postings in a
particular group, click the post message button. You're done with your
first one! Be Honest and it will truely work for you:
Congrats!
REMEMBER, THE MORE NEWGROUPS YOU POST IN, THE MORE MONEY YOU WILL
MAKE!! BUT YOU HAVE TO POST A MINIMUM OF 200!That is it You will begin
receiving money in your account from around the world within days! JUST
MAKE SURE ALL THE ADDRESSES ARE CORRECT. Now the WHY part out of 200
postings: Say I receive only 5 replies (a very low example). So then I
made $5.00 with my name at #6 on the letter. Each of the 5 persons who
just sent me $5.00 make the MINIMUM 200 postings, each with my name at
# 5 and only 5 persons respond to each of the original 5, this is an
additional $25.00 for me. Now those 24 each make 200 minimum posts with
my name at #4 and only 5 replies each. This brings in an additional
$125.00. Those 125 persons turn around and post the MINIMUM 200 with my
name at #3 and receive 5 replies each, I will make an additional
$625.00. Ok, now here is the FUN part, each of those 625 people post a
MINIMUM of 200 letters with my name at #2 and they receive 5 replies
each. That just made me $3,125.00!!! Those 3125 persons will all
deliver this message to 200 newsgroups with my name at #1 and if still
5 persons per 200 react, I will receive an additional $15,625.00!! With
an investment of only $5.00!! A - M - A - Z - I - N - G - !! When your
name is no longer on the list, you just take the latest posting in the
newsgroups, and send out another $6.00 to Email Addresses using Paypal
on the list, putting your name at number 6 again. And start posting
again. The thing to remember is that thousands of people all over the
world are joining the Internet and reading these articles everyday.
JUST LIKE YOU ARE NOW!! So, can you afford $5.00 to see if it really
works?? I think so! People have said, "what if the plan is played out
and no one sends you the money? So what! What are the chances of that
happening when there are tons of new honest users and new honest people
who are joining the internet & newsgroups everyday and are willing to
give it a try?? Anyway, it is only $5.00 for a chance at thousands.
Estimates are at 20,000 to 50,000 new users, every day, with thousands
of those joining the actual Internet. Remember, play FAIRLY and
HONESTLY and this will really work. There's no use trying to cheat for
only $5.00 *** Pls. use only opt-in resources for this material it will
work for you and it works much faster without soliciting or spamming
and higher responses*** !!! With warm wishes, bless you and your loved
onES
Woody
Guest
Posts: n/a
It is time to stop playing. You need to determine what readiness flags are
not set and find what is causing them not to be set. Any time you reset the
computer all readiness flags are reset and it can take several drive cycles
to set them. This means the car has to set until cold between drive cycles.
Pulling the battery resets the codes. Find a mechanic or dealer that can use
the tester and determine the problem. These aint the old days where you
could blindly throw parts at a problem to fix it....
<matt.stern@gmail.com> wrote in message
news:1114454179.003286.40180@l41g2000cwc.googlegro ups.com...
Colonel Panik
Sep 20, 2014 11:48 PM
Professor
Oct 4, 2005 08:30 AM
Rodo
Jul 30, 2005 02:30 AM
dwolgast@gmail.com
Jul 26, 2005 12:31 PM
phelper
Jun 27, 2005 08:22 AM
