'92 Accord TCU
Old May 4, 2005 | 04:44 PM
Tixin
Guest
Posts: n/a
'92 Accord TCU
My auto transmission was randomly stuck on third, a classic TCU failure
symptom! I decided to open up the TCU and play with it before
purchasing a replacement unit. I as inspect the board, I found two
adjacent transistor (220uF) and resitor (10K Ohm) burned. Went to Radio
Shack, purchased the two items for a grand total of $2.29, replaced,
and the problem is fixed! Hope this post helps someone with the same
TCU problem.
motsco_ _
Guest
Posts: n/a
Re: '92 Accord TCU
> TCU problem.
I have a PDF and a link where a guy explains how to do that fix . .
apparently it's very common for the caps to eventually fail, which takes
out the other components. google.com is a great tool for such stuff.
'Curly'
chip
Guest
Posts: n/a
Re: '92 Accord TCU
On Tue, 26 Apr 2005 10:09:18 -0600, "motsco_ _" <"motsco_
don't confuse people, the value you give for a transistor is in
micro-farads, which is a capacitace measurement. some people only
read and have no understanding of what they are doing.
I've re-built several of these for people. it is cheap and easy
>> TCU problem.
>'Curly'
Tixin
Guest
Posts: n/a
Re: '92 Accord TCU
Yes, you are correct. It was a capacitor, not transistor. Thank you for
catching the mistake.
Mike
Dec 23, 2008 03:30 PM
Fred
Jul 6, 2005 12:38 AM
KGT
May 15, 2005 07:30 PM
Phil Budgell
May 6, 2005 11:47 AM
Steppenwolf
May 4, 2005 11:16 AM
