uneven rear springs? need insight on this
Old Oct 9, 2007 | 10:22 AM
bojangles's Avatar
Question uneven rear springs? need insight on this
So i was walkin to my car one day after class and noticed that the rear-left side of my car sat a bit lower than the rear-right side. i thought i was due to the uneveness of the parkin spot but later on, i noticed the same condition on a flat surface. any ideas of how to fix it? should i even worry?
Old Oct 9, 2007 | 12:51 PM
quangalang's Avatar
you shouldnt even worry, pretty much every car in the world are uneven
Old Oct 10, 2007 | 04:31 PM
Evotech8's Avatar
Here one method I've used a few times with success.
On the low side of your car just add a rubber spacer pad on the upper rear spring perch to level out the car.
Find a thick rubber mat and cut in the shape of the stock upper rubber spring perch. Sandwich the two pieces together, reassemble, and lower the car. Voila!
Old Oct 19, 2007 | 10:15 PM
sorcerio's Avatar
Mine has this too I just noticed it recently. Seems to be about an inch, but it's noticeable. I just got it new in June. Gonna take mine in to the dealer to get the warranty hook-up. They should be able to just do a quick alignment, right?
Old Oct 19, 2007 | 11:25 PM
spoonek4's Avatar
U can sure bring it back to the dealer. But first empty the stuff from your car and check it again yourself after a few days.
I've actually see someone have a trunk fully packed with different stuff(basketball, roller blades, bottles of water, jackets, laptop etc etc) and complaint the ride height is un-even.
Old Oct 22, 2007 | 02:50 AM
spoonek4's Avatar
The front fender well is bigger than the rear ones, plus the stock rear springs seems to be really really soft that it sits lower even after I applied my E-brake.
Old Oct 22, 2007 | 02:14 PM
07fitsport's Avatar
i know on my ford truck i had it was same where driver side had slight lower than passanger side..it was built that way on all of them..not a defect so dont know if it is a factory lean or not
Old Oct 22, 2007 | 03:16 PM
smatts's Avatar
Honda Fit Forums Moderator
I thought I read somewhere that the driver side should be a bit higher by spec, because when you are driving your car alone most of the time it evens out with the drivers weight? Maybe I heard that wrong.
Myxalplyx
Racing
24
May 22, 2015 02:36 PM
DrKelso
Sep 12, 2009 06:36 PM
AWDturbo
Oct 27, 2008 04:00 AM
Tofuman
Aug 31, 2008 03:24 PM
prossett
Dec 9, 2007 10:40 PM
