battery corrosion
Old May 4, 2005 | 04:44 PM
disallow
Guest
Posts: n/a
battery corrosion
Hi,
I replaced my battery with a Canadian Tire special
last year in March. I looked at it today, and
it is corroded super bad around the battery
leads, and is even creaping down the battery.
System is charging at 14.4V (in spec according
to haynes) so I don't think its an alternator
prob. And nothing goes dim or anything when
i put it under load or slow down.
Any ideas?
t
TeGGeR®
Guest
Posts: n/a
Re: battery corrosion
"disallow" <loewen_t at yahoo.ca @> wrote in
news:7554568705aa67212a479afa38c4962e@localhost.ta lkaboutautos.com:
> Hi,
> Any ideas?
> t
Somebody broke the case/terminal seal through mis-handling.
A thick baking-soda/water paste will solve your current problem. To keep it
from coming back, you can either replace the battery, or get those felt
donuts that are impregnated with an acid-neutralizing solution. UAP should
have them.
Slathering Sil-Glyde or other hi-temp grease may also sufficiently prevent
atmospheric oxygen from contacting the acid from the existing battery.
TeGGeR®
www.tegger.com/hondafaq/
Old May 6, 2005 | 11:47 AM
disallow
Guest
Posts: n/a
thanks tegger
MTLian
Jan 15, 2013 02:32 PM
ccaleb02
Nov 29, 2008 09:56 AM
Remco
May 4, 2005 11:16 AM
Remco
piclistguy@yahoo.com
