static electricity shock when exiting car (97 Accord) - anti-static straps?
Old May 15, 2005 | 07:30 PM
James C. Reeves
Guest
Posts: n/a
Re: static electricity shock when exiting car (97 Accord) - anti-static straps?
I remember seeing these on many cars back in the 1960's. If they worked as
advertised, wouldn't they be required equipment on vehicles?
<techman41973@yahoo.com> wrote in message
news:1115944199.628928.241570@z14g2000cwz.googlegr oups.com...
> Many are familiar with the static electricity problem when exiting
> their car. Apparently it has something to do with some of the newer
> tire compounds. I have heard solutions ranging from spraying cloth
> seats with a fabric softener solution to "remembering" to touch the
> metal frame before leaving your car.
> I saw another option that seems much more practical.
> I am wondering if these things actually work.
> http://members.cox.net/ylosk/private...rth_ground.htm
> If any of you have tried this type of solution please let me know it
> works. Thanks
jim beam
Guest
Posts: n/a
Re: static electricity shock when exiting car (97 Accord) - anti-staticstraps?
> works. Thanks
i have bando anti-static belts on my '89 civic & i never get a jolt -
not that i chose those belts for that reason, but i noted the label
while installing. is this a recent phenomenon with you? does it
coincide with a belt change?
Tim Zimmer
Guest
Posts: n/a
*-Use a chrome (and grounded) gear shift knobs.
*- Pluck chrome thumbtacks onto steering wheel, grounding it.
*-Use a plain brass key (instead of insulated a genuine ignition key)
The passenger isn't protected, so don't let him
*fill up* that gas tank.
MAT
Guest
Posts: n/a
> In my Toyota, I clamp my hand firmly on the metal window frame,
> then step out of my car, and remove my hand once the rest of
> me is completely clear of the car. But sometimes the static
> still occurs ( eg. if I let go my hand, then touch the car again
> immediately, I get the zap ). So there must be more to it than
> that.
I find that if I am very deliberate about this, I can avoid the shock. I
think it works best if you are holding onto an *unpainted* part of the car,
I use the steel door jamb and let my foot rest on the ground for a second or
2 and then proceed to close the car up.
Fifty Hertz
Guest
Posts: n/a
An antistatic strap won't protect you
> unless you wire it to yourself and throw it on the ground before getting
> out.
> Then slide it on the ground when you walk.
I've been doing that for decades. Drives my wife crazy.
The Real Tom
Guest
Posts: n/a
>works. Thanks
Actually I've found air humidity has more to do with static discharge.
Static electricity is normally built up moving against fabric, and it
it's humid, it is discharged to the air with no sense of it. But when
it's dry, no discharge happens till you touch something and that's a
zap.
You might notice it more if you live in dry areas, or run you a/c
alot, but you can help prevent the build up if you fight static at the
source. I've heard of people wiping down car seats with new dryer
sheets when they clean their car out. This imparts some of the anti
static chemicals on the seat. I've been even told that one guy used
downy in his carpets when cleaning them to knock down the static zaps.
hth, please tell us what you found out.
later,
tom @ www.CarFleaMarket.com
Erik
Guest
Posts: n/a
In article <1115944199.628928.241570@z14g2000cwz.googlegroups .com>,
> http://members.cox.net/ylosk/private...p_earth_ground
> .htm
> works. Thanks
Static straps have been around forever. Back before they started
compounding conductive materials in tires, they were most popular.
I've installed a few for folks over the years, and have had better luck
trying to get them as close as possible to the 'track' line of either
the L or R tires... so the driver can straddle road debris without the
strap slapping everything. They don't look as good there though. An 'Old
Timer' mechanic friend tells me they occasionally get wrapped up in, and
are ripped off by road debris, and should be mounted so they can break
away without doing damage to the vehicle.
Some large aircraft have then to this day, they're small, and hang down
between the tires of the main landing gear 'bogie trucks'.
Aircraft of all descriptions are always grounded before fueling... if
being fueled from a truck, the A/C and truck are also grounded together.
Spraying your car seats down with some of that laundry anti static spray
stuff will help some... they also used to sell it at Radio Shack to
spray on carpets around computers.
If you know your charged up, and want to ease the shock a little, hold
onto the metal part of a key, then touch something grounded with same
(so the arc happens between the key and the grounded object). Wetting
your fingers to make a little better contact between you and the the key
helps a little more.
I have a neighbor who's home carpet is really bad about static...
especially when the humidity's low in the winter. I hold my keys the
whole time I'm over there, and ground myself regularly. Switch plate
screw heads usually work wonderfully... or should anyway. SNAP!
Erik
Old Wolf
Guest
Posts: n/a
that.
« Paul »
Guest
Posts: n/a
Yes. Women blow up at the gas pumps.
I have a number of videos of people blowing up.
I worked with API and PEI researching the static vs. gas dispenser issues.
We have not been able to come up with a solution other than education of
the pumping public. We use the vids in training sessions.
TeGGeR®
Guest
Posts: n/a
"« Paul »" <"=?iso-8859-1?Q?=AB?= Paul »"@houston.rr.com> wrote in
news:4284192A.AC2DCC43@houston.rr.com:
> That static charge is caused by sliding your synthetic covered butt
> on a synthetic covered seat.
So does this mean I have to stop wearing polyester leisure suits? They're
back in style again, you know.
> getting out. Then slide it on the ground when you walk.
> The static is on you, not the car.
> Simple physics.
> Read up on it.
Wanna see static? I'll show you static!
http://www.tegger.com/hondafaq/misc/static.avi
Don't EVER get back into your car after putting the filler nozzle into the
filler neck!
I can't bear to show this one to my wife, she'd never dare to fill up ever
again!
TeGGeR®
« Paul »
Guest
Posts: n/a
> works. Thanks
on a synthetic covered seat. An antistatic strap won't protect you
unless you wire it to yourself and throw it on the ground before getting out.
Simple physics.
Read up on it.
y_p_w
Guest
Posts: n/a
> works. Thanks
I've seen grounding straps of all types for years. There's nothing
revolutionary. I suppose one problem is that dragging a piece of
metal across the ground can also cause sparks.
Guest
Posts: n/a
works. Thanks
Old May 18, 2005 | 02:25 AM
ed
Guest
Posts: n/a
I recently saw a FEMA video of a person going in and out of the car while
they were fueling.
It was to prove static caused the fire that ensued in the clip, rather than
a cell phone the person was talking on. Just a passing thought.... ya
gotta be careful.
Old May 18, 2005 | 01:38 PM
ed
Guest
Posts: n/a
anyone get her phone number by chance? :)
Napalm Heart
Guest
Posts: n/a
"« Paul »" <"« Paul »"@houston.rr.com> wrote in message
news:4284192A.AC2DCC43@houston.rr.com...
newer
the
it
> > works. Thanks
getting out.
> Simple physics.
> Read up on it.
Interesting. I normally wear all-cotton pants and have cloth seats in
my vehicles. I get a static discharge when getting out of them unless
it is there is high humidity.
Ken (MI)
Old May 18, 2005 | 11:20 PM
« Paul »
Guest
Posts: n/a
> Ken (MI)
I bet the seats are a synthetic plastic material.
More than likely the entire interior of your vehicle is plastic.
Floor mats, arm rests, seat padding, etc.
Old May 22, 2005 | 10:16 PM
Jim
Guest
Posts: n/a
Wow, I never knew others had this problem also. I have a 2005 Civic. And
it's a BIG shock! I have to touch the door frame and >crack< there it goes!
Probably should inform the dealer...
> works. Thanks
Napalm Heart
Guest
Posts: n/a
news:428BD4BD.47F1B28A@houston.rr.com...
seats in
unless
> > Ken (MI)
That may well be, but why is this something that has just started
occurring after I put new tires on my vehicles?
Ken
Elmo P. Shagnasty
Guest
Posts: n/a
In article <118vnkjil9pihc2@corp.supernews.com>,
This is common with the composition of some tires. They build up static
with friction with the road, and can't dissipate it. You become the
path by which it dissipates once you touch the body of the car.
