Are new Hondas maintenance free?
Old May 15, 2005 | 07:30 PM
FanJet
Guest
Posts: n/a
Re: Are new Hondas maintenance free?
"jim beam" <nospam@example.net> wrote in message
news:dI-dnV2sket57BvfRVn-sQ@speakeasy.net...
> Elmo P. Shagnasty wrote:
>> In article <jason-1405051024490001@pm4-broad-50.snlo.dialup.fix.net>,
>> jason@nospam.com (Jason) wrote:
>>>>Ask him what happens if the timing chain breaks. Does the engine trash
>>>>itself, or not? I think Toyota's are the non-interference type which
>>>>don't trash themselves. At any rate, that's the important question. It
>>>>doesn't matter if it's a belt or a chain. There's still chance for
>>>>breaking, and there's still a requirement to change (although a chain
>>>>*should* go much farther in theory).
>>>Great post. It's my opinion that a broken timing belt would in most cases
>>>do less damage to an engine than a broken chain.
>> That depends on whether the engine is an interference design or a
>> non-interference design.
>> It's not just the physical belt or chain whipping around in there; it's
>> the pistons and valves you have to worry about.
>> With Honda, the valves go down inside the combustion chamber. If the
>> timing belt or chain breaks, the valves stay down there when the piston
>> comes back up to top--and all hell breaks loose when they meet. That's
>> called "interference".
>> If the engine is designed, however, such that the valves don't go down
>> inside the combustion chamber, but rather stay outside the combustion
>> chamber, it doesn't matter what happens when the belt or chain breaks.
>> The engine quits running, but a simple belt/chain replacement fixes the
>> problem. No trashed engine to worry about.
> but you don't have the performance to worry about either - as a general
> rule at any rate. in principle, a higher compression ratio and more
> aggressive valve timing/higher lift cams both contribute to better
> performance, but require "interference". so it's a trade-off. other
> factors such as combustion chamber design, port/valve design, can help
> produce a high compression non-interference engine, but what's good for
> non-interference tends to be less good for chamber design, i.e.
> efficiency, emissions, detonation tendency, etc. did i mention that it's
> a trade-off?
>> As far as the earlier comment regarding timing chains stretching, that
>> happened to my brother's 92 Infiniti Q45. He had to replace both timing
>> chains, at some unholy cost ($2700 comes to mind). It wasn't that they
>> broke, but rather that they had stretched far enough out of spec.
> belts are good. people whine about cost of preventive maintenance, but
> that's a function of dealer gouging, not design principle. it doesn't
> take 4 hours to change a belt on a civic, regardless of what it says on
> the invoice.
Belts are certainly good for $dealerships$. Their replacement isn't
preventive maintenance, it's scheduled maintenance - big difference. If
Honda used a decent chain, the customer wouldn't need to deal with it. The
Q45 issue was an anomaly. I'm sure there's the occasional Honda spun bearing
or some other oddity. Maybe the customer ought to replace them every 80K.
jim beam
Guest
Posts: n/a
>>> If Honda used a decent chain, the customer wouldn't need to deal
>>> with it. The Q45 issue was an anomaly. I'm sure there's the
>>> occasional Honda spun bearing or some other oddity. Maybe the
>> if you drive some piece of v8 detroit iron with less than 40 bhp per
>> liter, you're not going to notice much difference with a bit of chain
>> stretch. and cam timing errors in excess of 10 degrees of crankshaft
>> are not unknown. belts don't stretch so they remain dead-on with
>> timing right up to replacement day. you want a high performance engine?
> One forgets that chains put a certain amount of stress on motor oil.
> If people are lax about their oil change intervals and/or use poor
> quality oils, chains have been known to crap out. Chains create
> their own difficulties with OHV engines. Belts don't need any
> lubrication.
that's right - the longer travel for overhead cams is a much bigger deal
for a chain at high revs than for a belt. belts have much less mass.
chains for block mounted cams where the runs are short are just fine.
jim beam
Guest
Posts: n/a
> news:toKdnQNjm5DHURvfRVn-og@speakeasy.net...
>>>>>>>trash itself, or not? I think Toyota's are the non-interference type
>>>>>>>which don't trash themselves. At any rate, that's the important
>>>>>>>question. It doesn't matter if it's a belt or a chain. There's still
>>>>>>>chance for breaking, and there's still a requirement to change
>>>>>>>(although a chain *should* go much farther in theory).
>>>>>>cases
>>>>a trade-off?
>>>>the invoice.
>>>The Q45 issue was an anomaly. I'm sure there's the occasional Honda spun
>>>bearing or some other oddity. Maybe the customer ought to replace them
>>>every 80K.
>>stretch. and cam timing errors in excess of 10 degrees of crankshaft are
>>not unknown. belts don't stretch so they remain dead-on with timing right
> Sure. Try the Nissan VQ series (just one example). No belts, very high
> performance. You repeatedly forget to mention the fact that engines with
> chain driven cams also feature chain tensioners, preventing the cam timing
> errors you're worried about.
not so. chains /do/ have tensioners, but by definition, they are on the
"slack" side of the chain and make absolutely no difference whatsoever
to timing drift.
> So, chain driven cams + decent normal
> maintenance = no problems. Belts + decent normal maintenance = big $$
> scheduled maintenance. Your choice.
sorry, belts came /from/ v. high performance applications & migrated
/to/ stock vehicles. this is not to say that chains can't work in high
performance vehicles, but with the mass of the chain, they're not suited
for high revs.
now, if you have a chain driven vehicle and can allow for drift caused
by wear, as i believe is done in some of the recent variable valve
timing engines like porsche, then sure, you can marry performance, revs
& longevity, at least in theory, but then again, if you're dropping 6
digits on a porsche, i really don't think the cost of the maintenance is
uppermost among your buying considerations.
Sparky Spartacus
Guest
Posts: n/a
> lubrication.
So, like everything else in life, it sounds like a trade off, not a
white hat/black hat issue.
y_p_w
Guest
Posts: n/a
>> If Honda used a decent chain, the customer wouldn't need to deal with
>> it. The Q45 issue was an anomaly. I'm sure there's the occasional
>> Honda spun bearing or some other oddity. Maybe the customer ought to
> are not unknown. belts don't stretch so they remain dead-on with timing
lubrication.
FanJet
Guest
Posts: n/a
news:26WdnTJHd7-QfBvfRVn-1g@speakeasy.net...
>> sure! you gonna put one in my 98 civic CX?
> iirc, that's 106 bhp from a 1.6L = 66 bhp/L for the base model.
> a 97 corvette is 345 bhp from 5.7L = 60 bhp/L.
> which is the "better" engine?
Cipher HP/MPG and you'll have the answer.
FanJet
Guest
Posts: n/a
>>>>>cases
>>>a trade-off?
>>>the invoice.
>> every 80K.
errors you're worried about. So, chain driven cams + decent normal
jim beam
Guest
Posts: n/a
SoCalMike
Guest
Posts: n/a
jim beam
Guest
Posts: n/a
>>a trade-off?
>>the invoice.
yahmed
Guest
Posts: n/a
Hi,
I recently took a test drive for a new Corolla and the dealer told me
it does not require any tuneups for next 12 years or 160000km. All you
need is regular oil changes (every 6 months or 8000km)
Instead of timing belt, it has timing chain that automatically adjust
itself with time so no replacements are required. He was not sure about
water pump.
Just wondering, if he was lying? Are there any other costs like
radiator fluid chages etc? (I think its a question for Toyota group)
Now I am curious does Civic also comes with these features?
Thanks,
Elmo P. Shagnasty
Guest
Posts: n/a
In article <dI-dnV2sket57BvfRVn-sQ@speakeasy.net>,
You can't deny that there's a bunch of labor involved in getting to the
timing belt. That some dealers gouge is not in question, but even the
best dealers have to charge quite a bit for that bit of preventive
maintenance.
> it doesn't
> the invoice.
It doesn't take you, but I've seen techs for whom it takes quite a bit
longer.
jim beam
Guest
Posts: n/a
it's a trade-off?
the invoice.
Elmo P. Shagnasty
Guest
Posts: n/a
Jason
Guest
Posts: n/a
In article <elmop-2F4998.20313513052005@text.usenetserver.com>, "Elmo P.
Shagnasty" <elmop@nastydesigns.com> wrote:
> In article <1116013866.885890.35010@z14g2000cwz.googlegroups. com>,
> Don't believe that. Timing chains do require replacement as well.
do less damage to an engine than a broken chain. However, if you change
the timing belt or timing chain about every 50,000 to 60,000 miles--it's
very likely that the owner of the car would never have to worry about the
consequences of a broken chain or belt.
NEWSGROUP SUBSCRIBERS MOTTO
We respect those subscribers that ask for advice or provide advice.
We do NOT respect the subscribers that enjoy criticizing people.
Elmo P. Shagnasty
Guest
Posts: n/a
Jason
Guest
Posts: n/a
> Hi,
> water pump.
> Thanks,
New car dealer want to sell as many new cars as possible. It should not
shock you or anyone else that car companies try to make customers believe
that their vehicles will last forever without ever needing any major
service. Most of the people in this newsgroup know that we need to service
our vehicles if we want to make them run 200,000 miles.
jim beam
Guest
Posts: n/a
yahmed wrote:
> Hi,
> water pump.
> Thanks,
yes, the honda has the same "tuneup" schedule of 100,000 miles, but a
longer oil change interval of 12,000 miles, iirc. check the owners
manual. i expect all other operating factors to be similar.
timing chains have a small advantage on reliability, but are much
inferior in terms of timing drift caused by wear.
zZero
Guest
Posts: n/a
I have mine repainted every thirty years even if it doesn't need it.
S.S.
Guest
Posts: n/a
yahmed wrote:
> Hi,
> water pump.
> Thanks,
Look, NO car is maintenance free. All cars, including Honda and Toyota,
require regular maintenance including fluid changes and replacement of
normal wear-and-tear items (e.g. brake pads). The difference is that Hondas
and Toyotas experience less problems with non-routine items than other
manufacturers, the big 3 in particular.
The Civic may cost a little more to maintain in the long run than the
Corolla solely because of having to replace the timing belt on the Civic,
but otherwise, the maintenance on both is about the same.
