94 civic transmision failure
Old May 18, 2005 | 02:25 AM
joe
Guest
Posts: n/a
AT failed at 60mph. It disengaged to neutral. Actually not sure about
it. It was a highway emergency
and car lost any power, engine rpm dropped to 900, high pitch/grinding
sound. After a tow back to
home I found that ATF dipstick was probably not seated firmly in its
hole when battery was serviced
a week ago. It probably caught teeth of some gear inside. Now the
dipstick is crooked and some
half of inch of it is filled out. Probably particles of this grinding
are inside and AT is at lost. There is
no MIL code saved. Lock up solenoid is OK.
It is a very good car and I am not given up. I just had the exhaust
replaced and new, good tires.
I need some advice what to do next. What damage can be found inside?
Can it be that gear steel
is harder than dipstick and not harm was done?
Thanks
Joe
motsco_ _
Guest
Posts: n/a
Re: 94 civic transmision failure
> Thanks
> Joe
There is a magnetic drain plug, which should catch particles that come
near it, but not very well if it's never been cleaned. What's your
mileage and service history on that tranny to date? Shouldn't matter how
far the dipstick goes in, unless it's realy been bent by somebody, or
the washer isn't intact. Has Honda Z1 always been used in the tranny?
'Curly'
joe
Guest
Posts: n/a
At 48Kmi ATF drained and refilled. Same at 90Kmi. Both times no flush,
but genuine Honda used.
Now tranny has 105Kmi. Never had any problem. I suspect that when my son
was installing new battery
he must have hit the dipstick and bent it. For some reason it was fine
for a week and then was sucked
into a gear.
Joe
> how far the dipstick goes in, unless it's realy been bent by somebody,
> or the washer isn't intact. Has Honda Z1 always been used in the tranny?
> 'Curly'
gkitf16
Apr 16, 2019 06:41 PM
tj_boof
Dec 28, 2006 12:16 PM
bekahl07
Sep 25, 2005 12:30 AM
Raaj
May 15, 2005 07:30 PM
mmdir2002@yahoo.co.uk
May 4, 2005 11:16 AM
