'90 Civic Driveability Issue
Old May 23, 2005 | 05:01 PM
WaterWatcher
Guest
Posts: n/a
My '90 Civic LX driveability seems to be degrading. Under light throttle,
it surges and hesitates slightly. It has always done this to some degree
but it seems worse now that it has 102K miles on it. It runs fine under
acceleration and idles good. I've recently replaced the plug wires, rotor
and cap and the O2 sensor is fairly new. Spark plugs are in good shape. I
really notice it after I've driven another car for a while. Any suggestions
as to what to check to smooth things out?
Thanks,
Ray
Old May 28, 2005 | 04:41 PM
r2000swler@hotmail.com
Guest
Posts: n/a
Re: '90 Civic Driveability Issue
Try running some Chevron gas through it.
And the Chevron FI cleaner is very good.
Slightly dirty FIs can cause that problem.
Some of the other FI cleaners can do a
good job, but Techron?, Chevrons brand,
always does a good job cleaning the FIs.
It may take more then one tank of Chevron gas,
and one run of FI cleaner.
Terry
motsco_ _
Guest
Posts: n/a
> Thanks,
> Ray
Try a tank of Gasohol, or two.
'Curly'
merlotbrougham@hotmail.com
Guest
Posts: n/a
Change the fuel filter.
throttle,
degree
under
rotor
shape. I
suggestions
> Thanks,
> Ray
Guest
Posts: n/a
I have seen fuel filters clog and stop an engine from starting, or
accelerating, or runing at high RPM, but I haven't seen one
cause slight miss/hesitation/stumble. It is good practice to
change one by the maintinance schedule, but I suspect he
will find changing the fuel filter won't help.
Terry
WaterWatcher
Guest
Posts: n/a
<r2000swler@hotmail.com> wrote in message
news:1116934814.783659.129380@g49g2000cwa.googlegr oups.com...
> Terry
I used to use Chevron until the price went up so much. Now I'm using Arco.
I'll give Chevron gas a try again, and maybe the Techron too. Thanks for
the suggestion.
Ray
Guest
Posts: n/a
> Terry
Hmmm. That was exactly the case with my '94 Marquis. Changed it and the
stumbling at low RPM's stopped. With the stuff he's done already, I'd
spend the 5 bucks and give it a try before paying for FI
servicing/replacing. Sounds like a fuel problem anyway.
Rocky
Jul 22, 2005 02:36 AM
chibitul
Jul 13, 2005 12:05 AM
Genboy
Jun 27, 2005 08:22 AM
disallow
May 4, 2005 04:44 PM
Drogotti
May 4, 2005 11:16 AM
