Sponsored by:
Sponsored by: CARiD
Fresh Intake Idea
Old Dec 13, 2007 | 12:50 PM
prossett's Avatar
Fresh Intake Idea
Has anyone done, seen or heard of keeping the stock air intake tubing, just removing the flat rectangular filter, and instead attaching a high-flow foam filter to the end of the stock pipe, down in the fender?
Old Feb 15, 2008 | 07:06 PM
fshwcrs's Avatar
What's your hypothesis?
Old Feb 15, 2008 | 10:55 PM
prossett's Avatar
Well, the stock piping is designed to pull in fresh air from the front left fender, but no after-market systems I've seen keep that feature - so I was wondering if anyone had found a way to simply free up air flow by keeping the full stock piping, removing the stock filter altogether, and adding a low-profile filter at the fender.
It would certainly not be as free-flowing as larger diameter tubing, but it should be an improvement over stock, cheap, and making use of what's already there.
Just an idea.
The difficulty I suppose would be in fitting the right kind of filter at the end, where the stock entrance of air is.
Old Feb 15, 2008 | 11:00 PM
accordguyintake's Avatar
i don't think it's good to place a filter at the end. What about when it gets wet and stuff? It's probably best if you just wanna take out the old filter and put a new one in its place.
Old Feb 15, 2008 | 11:06 PM
prossett's Avatar
Yeah, I realize it's just a weird idea, otherwise it would already be done.
How does the stock end of the air intake work? That doesn't suck in water...
Old Feb 15, 2008 | 11:17 PM
well i think that's why they designed the thing to go so low, probably water does enter the box at times, but will all that pipework crawling up into the box with insane incline, the water never reaches the actual filter.
(im just guessing )
Old Feb 16, 2008 | 12:24 AM
koolkevin1107's Avatar
doesnt work. I had a smart idea to block off those extra sections of pipe in the stock intake box to allow the air to travel much smoother, i actually lost horsepower and torque by trying 2 modify the stock airbox.
Old Feb 16, 2008 | 02:41 AM
Tofuman's Avatar
i think moving the location of the filter isn't going to change the rate of flow through the stock intake. if anything it will probably hurt performance. the air filter probably reduces the amount of air turbulence occuring in the piping and filter box before it reaches the TB. putting the filter at the very beginning of such an awkward shaped intake/box will probably cause turbulent air flow right before the TB. aftermarket CAI/SRI's have very smooth curved piping for less turbulence.
Old Feb 16, 2008 | 07:26 AM
greekdaddy000's Avatar
I've heard of people drilling large holes into the "box" assembly in order to allow more suction, but it would injest warm air from the engine bay.
Old Feb 17, 2008 | 01:47 PM
space cowboy's Avatar
when i was swapping out my headlight bulbs it seemed very tight in there, if you were to rig something up you would probably have to take it apart any time you want to change out your bulbs
Old Feb 17, 2008 | 08:48 PM
daviddahlb's Avatar
it would be easier to just rig something up to direct air up through the left fender, towards the aftermarket air filter.
Old Feb 18, 2008 | 10:55 AM
Arisenfury's Avatar
My Fujita SRI filter is right next to the rubber piece in the fender that feeds in the air that comes in through the hole in the front bumper.
Chitown Fit
Aug 7, 2020 11:36 PM
Radi
Nov 29, 2018 04:56 PM
wdb
Aug 7, 2012 01:27 PM
zymo
Mar 26, 2011 12:34 PM
p1driftfiend
Jun 20, 2006 08:16 PM
