'91 Accord won't start when wet
Old May 28, 2005 | 04:41 PM
caroline_t
Guest
Posts: n/a
I have a '91 accord with 230,000 miles on it. When the car is wet, I have
to hold the key for about 5-10 seconds to get the engine to catch. When
it catches, it runs rough for 5-10 minutes. It has been raining for 5
days and now the car will not "catch" at all. The engine turned a couple
times but never caught. The spark plugs are new (less than a year, or
10,000 miles). I've checked all the fuses. Any suggestions? Thanks in
advance.
merlotbrougham@hotmail.com
Guest
Posts: n/a
Re: '91 Accord won't start when wet
Unusual. Check your battery terminal connections. Clean them well. Are
they wet?
> advance.
TeGGeR®
Guest
Posts: n/a
"caroline_t" <cmtwomey@[withheld]> wrote in
news:3e3ccf0386e9c1b7ddf3a5a03c7984cd@localhost.ta lkaboutautos.com:
> have to hold the key for about 5-10 seconds to get the engine to
> catch. When it catches, it runs rough for 5-10 minutes. It has been
> raining for 5 days and now the car will not "catch" at all. The
> engine turned a couple times but never caught. The spark plugs are
> new (less than a year, or 10,000 miles). I've checked all the fuses.
> Any suggestions? Thanks in advance.
Replace the plug wires, and wipe out the inside of the distributor cap.
High-tension current (used to fire the plugs) is leaking off before it hits
the plugs.
Spend the extra $20 and get OEM from the dealer. You'll help save your coil
that way.
TeGGeR®
www.tegger.com/hondafaq/
Jason
Guest
Posts: n/a
In article <Xns9662944DE4DCEtegger@207.14.113.17>, "TeGGeR®"
> the plugs.
> that way.
I just wanted to tell the oringinal poster to check the distributer cap
for cracks when you finish cleaning it. It's easy to miss the cracks
unless you look very carefully at it. Some people replace the distributer
cap every 30,000 miles. If you have NEVER replaced the distributer cap--go
ahead and buy a new one.
NEWSGROUP SUBSCRIBERS MOTTO
We respect those subscribers that ask for advice or provide advice.
We do NOT respect the subscribers that enjoy criticizing people.
SadaYama
Guest
Posts: n/a
Yup. Like everybody said, replace distributor cap, rotor, spark plug
wires and coil wire and get the baby humming again.
motsco_ _
Guest
Posts: n/a
> advance.
If it's spinning OK, but not firing, try holding the pedal to the floor
and crank it for ten - fifteen seconds. If it starts, you've got one
injector leaking. Especially if the problem only happens if the car sat
overnight or longer. This is decscribed in your Owner's manual as
Flooded Engine, and the manual says it's OK to do it.
'Curly'
Rattus The RAT
Guest
Posts: n/a
"caroline_t" <cmtwomey@[withheld]> wrote in message
news:3e3ccf0386e9c1b7ddf3a5a03c7984cd@localhost.ta lkaboutautos.com...
shit, you beat me!
TeGGeR®
Guest
Posts: n/a
"Rattus The RAT" <rats_and_guns_n_roses@REMOVE-THIS-PARTyahoo.com> wrote in
news:bavle.2723$3D6.1368@newssvr12.news.prodigy.co m:
> shit, you beat me!
247K on my Integra. Original clutch too.
TeGGeR®
SoCalMike
Guest
Posts: n/a
> advance.
replace all with OEM parts:
distributor cap
rotor
spark plug wires
it should run then :)
Dan Beaton
Guest
Posts: n/a
"caroline_t" (cmtwomey@[withheld]) writes:
> advance.
As an emergency technique, you can spray 99% alcohol on the distributor
cap and wires, then let it evaporate before trying to start. This will
dispel water and make starting easier.
If you have been having many incidents of hard starting, check your oil
for the smell of gasoline. If you smell gas, your oil has been
contaminated and you should change your oil.
Dan
(This account is not used for email.)
motsco_ _
Guest
Posts: n/a
>>advance.
> Dan
Excellent point. If the engine has been flooding (see my previous
response) the oil will be stinking with gasoline, although a
non-mechanical type might not know how it should smell. I thought that
aduring a long drive the high heat and the PCV would extract / burn out
a lot of gas from the oil, no?
'Curly'
jim beam
Guest
Posts: n/a
>>> have
>>> couple
>>> advance.
>> Dan
> 'Curly'
depends if there's enough in there to ruin the film strength of the oil.
someone i knew deliberately put some kerosene in their oil to "flush"
it. and then drove it around. the journal bearings were hammered out
inside 10 miles & had to be towed home.
in the case above, it's safer to change. you can even do it without
changing the filter - will get rid of enough contamination to ensure
reliability until the next scheduled change.
motsco_ _
Guest
Posts: n/a
jim beam wrote:
>>>> I have
>>>> When
>>>> couple
>>>> Thanks in
>>>> advance.
>>> Dan
>> out a lot of gas from the oil, no?
>> 'Curly'
My question is, how much fuel will injected engines spray into a
non-starting engine, (or how much fuel will drip out of the pressurized
rail overnight if an injector is dribbling)? It's not like the old
carburetors (with accelerator pump) that could HOSE the fuel in there,
is it?
When my Odyssey flooded overnight, it seemed to take a while to get it
to start, but it was actually less than ten seconds, I'm sure. Gasohol
cured it.
I never thought to READ THE MANUAL to figure out the problem, at the
time. :-(
'Curly'
lincw@yahoo.com
Oct 28, 2011 02:44 AM
privett
Oct 15, 2005 12:30 AM
Fijoy George
Jul 24, 2005 11:53 PM
Randy MacKenna
Jul 1, 2005 12:32 AM
nospam_alan@yahoo.co.uk
May 4, 2005 11:16 AM
