New Gram Light Wheels?
Old Dec 19, 2007 | 11:48 PM
FormulaJDM's Avatar
I saw this wheel on Gram Lights web site, and assume its new? Its called G07CR. Looks like it would be a good fit for a Fit? (No pun intended) They make this in a 17x7 4x100 with a +43 offset. I'd love to see these in white on any color Fit. Anyone seen these before?
Link
Old Dec 20, 2007 | 02:16 AM
abcsr2ez4me's Avatar
THose look alot like the rims on the Mugen Dynamite ... search google images for Mugen Honda Fit... I swear theres a fit with rims just like that.
Old Dec 20, 2007 | 10:10 AM
doctordoom's Avatar
Supervillain
mm mm mm those look good
Old Dec 20, 2007 | 11:17 AM
TOOL's Avatar
Those are awesome wheels man, ive never seen them either.
Tyler
Old Dec 20, 2007 | 12:46 PM
doctordoom's Avatar
Supervillain
i like these a lot, do they look similar to the mazdaspeed3 wheels or am i mistaken?
Old Apr 29, 2008 | 09:15 AM
1stymer's Avatar
Will the 17x7 4x100 with a +43 offset cause issues/rubbing with stock springs?
I was planning on getting a set but they cost and arm and a leg.
Long time lurker. 1st post.
Old Apr 29, 2008 | 09:35 AM
Zangoose GD3 Blue's Avatar
how much is it...
Old Apr 29, 2008 | 06:09 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
OOOOoO! Those are damn nice!
17mm and +40ish offset can be pulled off. SD_MR_FIT should be able to chime in. Hes on 17's with I think +45mm offset. He had to do some mods for fitment, however its too low for fat hoe.
Old Apr 29, 2008 | 06:25 PM
Fitcapo's Avatar
I got motegi ff7 17x7 with a 42 offset and only time I rub is when I get a car full of people and i hit a bump the back rubs. Also stock springs.
Old Apr 29, 2008 | 11:20 PM
FormulaJDM's Avatar
Originally Posted by Zangoose GD3 Blue
how much is it...
I just googled "g07cr gram lights" looking for pricing/info and this thread came up as the top result! hahahaha....so much for good information on the web.
Old Apr 29, 2008 | 11:26 PM
SD_MR_FIT's Avatar
im here im here.
DAM i wanna rock those g07tas.
for sure..
uh, im tire tucking at the moment and i have no issues with rubbing. the only thing i had to do is the fender lining trick. the rubbing in the front was something else that came unbolted. so i though i was rubbing on something, when in reality my knuckle bolt that holds the rotor to the strut came loose.
if you dont carry people much then you dont have to try this mod.
i had to sand down my rear bumper by the rear fender, because my tire sticks out a bit in the rear. so it will hit under a heavy load. then again im on stock struts with cut 2 coil tein s.techs.
keep in mind that it work. i had a full car with luggage to the point where i couldnt see out my rear window and drove 600 miles up north on a bumpy road. no harm at all to the car.
make sure you get a 45 offset though. my buddy burbio has a 40 offset and hes on sportline springs and he rubbs often.
Old Apr 29, 2008 | 11:27 PM
SD_MR_FIT's Avatar
see your on stock springs....and you rubb with you have a full car.
im slammed on cut tein s.techs and i dont at all. very seldom do i rubb with people in the rear.
so that +3 offset helps out a lot. and i have a 17x7.5 wheel.
so with that being said. MAKE SURE YOU GET AT LEAST 45+ offset.
Old Apr 30, 2008 | 12:56 AM
1stymer's Avatar
From its official forums the wheels are JPY39k so around USD$375
CR
annunC8
Dec 16, 2012 08:15 PM
bradpeterson2
Apr 3, 2012 01:43 AM
seps
Aug 13, 2008 08:22 PM
HONDAMATIC
Apr 22, 2008 09:13 PM
randomracer
Jul 17, 2007 07:53 PM
