Sound dampening can cause rust?
Old Jun 3, 2005 | 01:06 AM
Frank
Guest
Posts: n/a
Hi all
Got some Dynamat to sound proof both my doors on my RSX. Last
weekend, I did the driver's door, both the outside door panel and
the inside panel. I dynamat approx. 3/4 of the door's outside
panel; I avoided the lowest 5 inch of the inside panel because I
wanted to keep the drainage holes clear. Because I live in the
rust belt of Ontario, I also applied some rust proofing in the
inside of the door while I was at it...
So far so good. However, I was thinking, is it possible that such
a material could *increase* the probability of rust in the inside
panel or in the doors? I mean, have you had any *direct*
experience with doors rusting out because of moisture that was
kept inside the door panel due to sound dampening material?
Perhaps an air pocket or rain water could seep between the
dynamat and cause the door to rust. BTW my car is a daily driver.
Hence the question: any experience with rust caused by sound
dampening material?
Thanks a million.
SniffinPopRocks
Guest
Posts: n/a
Re: Sound dampening can cause rust?
"Frank" <NOSPAM@NOSPAM.com> wrote in message
news:lIydnf6M7cfl-gPfRVn-qA@rogers.com...
> Hi all
> Got some Dynamat to sound proof both my doors on my RSX. Last weekend, I
> did the driver's door, both the outside door panel and the inside panel. I
> dynamat approx. 3/4 of the door's outside panel; I avoided the lowest 5
> inch of the inside panel because I wanted to keep the drainage holes
> clear. Because I live in the rust belt of Ontario, I also applied some
> rust proofing in the inside of the door while I was at it...
> So far so good. However, I was thinking, is it possible that such a
> material could *increase* the probability of rust in the inside panel or
> in the doors? I mean, have you had any *direct* experience with doors
> rusting out because of moisture that was kept inside the door panel due to
> sound dampening material? Perhaps an air pocket or rain water could seep
> between the dynamat and cause the door to rust. BTW my car is a daily
> driver.
> Hence the question: any experience with rust caused by sound dampening
> material?
> Thanks a million.
In my experience Dynamat is pretty tacky and when properly applied wont
create any air pockets for this to happen. I think the rust proofing you
applied is your best defense. nothing lasts forever and the dynamat is worth
it.
Scotty
Guest
Posts: n/a
Dynamat is applied with a heat gun so to remove all moisture as well as make
it plyable, once in rust will apear where it was going to appear before the
matting, go for it the stuffs great. Umm ,no, doesnt speed up the rust
process unless yoru trappign excess water in there with a poor install.
> Hi all
> driver.
> material?
> Thanks a million.
Professor
Guest
Posts: n/a
I think the only issue is how much moisture was present when the
coating was applied. That alone won't even cause trouble if the barrier
is complete and doesn't allow oxygen through... but if the barrier ever
becomes flawed... and there is trapped moisture... then that could be a
problem.
Professor
www.telstar-electronics.com
BMW ALPINA
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
23
Sep 10, 2017 03:38 AM
phuccer
Jul 24, 2010 03:02 PM
tourretired
May 11, 2010 09:39 PM
KiNgKuRnG
Mar 26, 2010 02:28 PM
eyedryve
Aug 6, 2009 08:57 PM
