'93 Honda Accord with some problems
Old Jun 8, 2005 | 09:16 AM
les2w
Guest
Posts: n/a
Last year at this time I had to have 3 mounts replaced. I am a girl in
college and am worried abotu cost as well as what is wrong with my car. It
gets to about 95 degrees here and when trying nto start my car it
struggles. When I pull up to a stop light my car will vibrate and shake
and just recently it has started to get noisey. The other day I noticed
something is leaking from my engine... I believe it is oil... Any ideas or
suggestions?
Professor
Guest
Posts: n/a
Re: '93 Honda Accord with some problems
Sounds like you have a number of problems that could be caused by many
things. Your time may be best spent researching a trustworthy garage in
your area to take a look at it...
Professor
www.telstar-electronics.com
motsco_ _
Guest
Posts: n/a
> suggestions?
If it runs OK when cool, but won't restart when you get back into it
(like at the convenience store), it's 99% this problem:
http://www.tegger.com/hondafaq/mainr...mainrelay.html
Until you get it fixed, if it doesn't start, leave the key ON, then
smack the dash on the left side of the steering wheel, which will make
the relay work for a few seconds (fuel pump will run) then you can start
it and the vibration of the engine will keep it working.
Find a friend to resolder it for you. It's a cheap fix and will probably
last a long time.
'Curly'
wannadoitmyself
Aug 29, 2005 01:31 AM
kathleen williamson
Aug 15, 2005 11:30 PM
Fijoy George
Jul 24, 2005 11:53 PM
Goomanjbs
Jul 11, 2005 05:50 PM
ibcarolek
May 4, 2005 11:16 AM
