Spring install pretty straight forward?
Old Jan 21, 2008 | 09:23 PM
davela72's Avatar
I've decided to go with the Progress springs for my Fit and am trying to plan out the install. I changed the suspension out twice on my '06 Rabbit and the fronts on that were a major PITA! It was a different set up than the Fit in where the strut sat in the knuckle. the axles had to come out of the hub to get enough clearance to get the strut out. Regardless, it sucked. the rear was similar to the Fit except it was IRS.
Anywho, I have an air compressor, impact and access to the VW spring compressor from work. I've had the rear springs out already to install the Progress RSB so I know thats easy.
Anything I need to know before tearing into this or any tools I need? I'd like to get the torque specs but am not ready to get the service manual yet. I have access to AllData Pro (online service manual for all car makes) and while there's not much on the Fit yet, there is the Civic. I would think the specs for the suspension components would be similar so I guess I could go by that.
Sorry for the book, just trying to get a game plan together.
Thanks!
Old Jan 21, 2008 | 09:34 PM
davela72's Avatar
I think I posted all that for nothing. I just found a DIY with the Skunk 2's, looks pretty easy!
Old Jan 22, 2008 | 02:34 PM
yeh, it's not hard to do. and you dont really need an impact gun to
do the work.
Old Jan 22, 2008 | 08:55 PM
davela72's Avatar
Ken, did you tighten all the bolts/nuts to the proper torque? I hate to say but being that I work at a dealership, albeit in parts, I know that technicians don't tighten everything to the proper torque, just tight.
Old Jan 22, 2008 | 11:29 PM
yah, i just tightened mine pretty tight, that's it. when i do more
delicate/sensitive parts i use a torque wrench but otherwise hand tight
is fine for me. im pretty familiar with my tools that i can do it by feel
and get it close enough.
ive yet to have a bolt come loose or break, cross thread, etc through
the years except for the cusco tower bar i installed on the Fit recently.
their torque rating is too low.
if you're anal, most definitely use your service manual and correct
torque's for each fastener.
Old Jan 23, 2008 | 12:29 PM
bosshogg's Avatar
Anyone gotta link to this info,
Old Jan 23, 2008 | 06:49 PM
davela72's Avatar
Sure do, How To: Install Skunk2 Lowering Springs for Honda Fit
Dave
Old Jan 23, 2008 | 07:13 PM
bosshogg's Avatar
Thankyou, Should be a walk in the park, I hope
Old Jan 27, 2008 | 12:14 AM
rabbitron's Avatar
post up a review on the springs once you've gotten some mileage on them. i'm thinking about picking up a set also.
Old Feb 23, 2008 | 03:13 PM
chaseerry's Avatar
I will be attempting a Skunk2 Spring install tomorrow, and was curious if anybody needed a spring compressor to complete the task?
Thanks!
Old Feb 23, 2008 | 06:47 PM
Thanks!
i used one when i removed the stock springs from the front. for
safety reasons, i recommend you use one... and wear gloves
and safety glasses.
Old Sep 19, 2010 | 09:43 PM
nosewitdot's Avatar
I'm bringing this thread back from the dead because the skunk2 spring install DIY link is dead....Does anyone have it saved on their hard-drive somewhere? I've been searching for it for an hour to no avail. I guess I can use tofuman's DIY as well.
Old Sep 19, 2010 | 10:03 PM
davela72's Avatar
Old Sep 19, 2010 | 11:05 PM
nosewitdot's Avatar
thanks! i've been looking for this one too! I'm just paranoid about the axel popping out
BankWalker
15
Oct 10, 2010 01:02 PM
kancerr
Mid-Atlantic Community
Sep 18, 2008 12:04 AM
fork_nSpoon
Jul 26, 2008 12:22 AM
doctordoom
Mar 25, 2008 01:48 AM
ccFit
Toronto Community
Aug 9, 2006 07:58 PM
