Megan Racing Street Coilover
Old Feb 1, 2008 | 04:29 AM
hkxstyle's Avatar
Honda FIT
Model Number : MR-CDK-FIT Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car. Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in knob at the top of the damper mount for easy access. Simple adjustments can be made to tune to your style of driving and comfort level desired. Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment. You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber. Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched. Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection. With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
Features:
- Spring Rates: 8kg Front and 10kg Rear
- 32 Levels of Adjustable Damper
- Pillow Ball Upper Mounts.
- Rubber Dust Covers.
- Adjustable Ride Height
- Aggressive Spring Rates
- Single-Cylinder Design
- Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
- All coilover damper kits come with 1 year manufacture-defect warranty.
- All Hardware is Included
MSRP: $1050.00
810 Shipped OBO. Its what I got it for so yea. Pm me if you have any quesitons
Old Feb 1, 2008 | 05:10 AM
sti-to-fit's Avatar
new
i thought these were only a bit over 800 new
Old Feb 1, 2008 | 08:41 PM
hkxstyle's Avatar
these are Brand new in box also
Old Feb 1, 2008 | 11:19 PM
nosewitdot's Avatar
where are you located?
Old Feb 2, 2008 | 01:34 AM
SD_MR_FIT's Avatar
hes in i think hacienda heights.
91745 zip
(from the invidia posting)
Old Feb 2, 2008 | 01:36 AM
JDMchris.com's Avatar
I run THIS
Originally Posted by hkxstyle
My car back in the day.
TofuShop
3rd Generation GK Specific Suspension & Brakes Sub-Forum
Aug 21, 2016 05:12 PM
TofuShop
May 6, 2016 09:01 PM
FELIXY69
Oct 26, 2009 09:49 PM
ShowstoppersUSA
72
Apr 14, 2009 02:10 PM
Battleendless
Canada Fit Forums & Clubs
Nov 26, 2006 12:01 PM
