Sponsored by:
Sponsored by: CARiD
Dent in passenger door :(
Old Feb 10, 2008 | 10:02 PM
farley's Avatar
I have a 3 month old fit LS and got hit by someones door in a parking lot, the dent is right on the crease of the door...just wondering what the chances are of getting it popped out without cracking the paint...anyone have the same issue thats been repaired??
Old Feb 10, 2008 | 10:04 PM
solbrothers's Avatar
pix? depends on the damage
Old Feb 10, 2008 | 10:06 PM
farley's Avatar
nah unfortunately i dont have a pic, but i can descride it, there is no cracked paint in the dent its about 2"-2.5" wide and maybe 1/2" deep in the middle of the dent its right on the door where it sticks out
Old Feb 10, 2008 | 11:08 PM
dank24's Avatar
Old Feb 10, 2008 | 11:24 PM
tecknical's Avatar
Originally Posted by dank24
does that actually work? cause my dad has about 3 dents in his car..
Old Feb 10, 2008 | 11:28 PM
dank24's Avatar
I know a kid with a bubble it worked on. But who knows, doesn't hurt not to try.
Old Feb 10, 2008 | 11:47 PM
tonyd3773's Avatar
Smile
If you read on the threads below the video (which by the way was super) that this only removes larger dents, NOT smaller ones.
For small dents replace the CPU Air Can with "Dry Ice".....heat the car dent with the hair dryer then hold the piece of dry ice on the dent wit a pair of pliers till that baby POPZ! GOOD LUCK
tonyd
Old Feb 11, 2008 | 12:49 AM
azncarbos's Avatar
dam if i knew this before i would has save $$$$ on my repair...im try w/ another car that has dent
Old Feb 11, 2008 | 12:53 AM
ascGD3's Avatar
lol yea pete that damage from last time
Old Feb 11, 2008 | 01:05 AM
azncarbos's Avatar
which one the door or the lip.... the lip i replace w/mugen lip and the door my friend she drove my car b/c i was too tired to drive after snowboarding, and she parking my car and rub against a big tire of those off road jeep,so that make nice dent on the rear door and part of the front door......
Old Feb 11, 2008 | 04:37 AM
SD_MR_FIT's Avatar
i had a small dent on my fender on my integra. i went to home depot...bought me a plunger and it actually worked. it popped right out. but i am going to try the dry ice thing, because costco members love to leave their carts around my car for some reason and i get tiny little dents everywhere.
Old Feb 11, 2008 | 02:39 PM
Snap Fit's Avatar
Wow! What a funny/wicked way to pop out a dent!
I weld a bit and even though every once in a while I have used cold rags to control distortion...I would not have thought of this in a million years!
Thanks for posting that link and other good info...Great job guys!
I cant say that I want a dent to try this on....but...
Old Feb 11, 2008 | 03:27 PM
greekdaddy000's Avatar
paintless dent removal
Old Feb 11, 2008 | 04:07 PM
+1 for PDR.
when the ding is over decorative lines you'll only be able to get about 85%
out though. but it might be enough.
DentWizard.com : Welcome and search your area.
Old Feb 12, 2008 | 12:09 AM
azncarbos's Avatar
Sorry to inform you guy but it didn't work...try it today on the my pilot it had a golf ball size dent on the driver door ....another myth busted...
Old Feb 12, 2008 | 01:35 AM
SD_MR_FIT's Avatar
boooo.
well i guess that saves me a bit of money...thanks for the info
Old Feb 12, 2008 | 10:07 AM
chaseerry's Avatar
I had a small ding right next to the door crease. Took my chances, and bought a Ding King at Advance Auto. Popped the dent out to where you can barely barely tell where it was originally.
Old Feb 12, 2008 | 04:10 PM
i have both traditional PDR tools (rods) and glue types.
either one would work but you have to remember if you pull out with
glue you *COULD* pull out too far and have high spots.
these cheep glue puller kits sometimes do not come with a knock down
tool and customers are left with high spots.
if you end up with a high spot you can use those disposable
chopsticks (just break it apart and use the one piece) and a
small hammer to tap it down. use a predetermined straight line
such as your garage door grid or wall or watever in the reflection
as a guide. when the line(s) are straight in the reflection, it means
the panel is flat.
Old Feb 13, 2008 | 03:43 AM
SD_MR_FIT's Avatar
the panel is flat.
great advice on the chopsticks. im going to try that on my moms car first.
Old Feb 13, 2008 | 08:49 AM
yep try the normal wood one, not the bamboo if you have them.
disposable chopsticks are soft vs a true knockdown tool which is
made out of hardend nylon backed resin so it provides a wider margin
for error.
