honda stalls on take off
Old Jun 27, 2005 | 08:22 AM
94_2dr_accord
Guest
Posts: n/a
my honda runs fine at idle, and even on a easy takeoff. but when i really
give it some gas it acts like it is a 2 cylinder instead of a 4. and then
usually about 4500 rpm's the other 2 kick in and it takes off.
S.S.
Guest
Posts: n/a
Re: honda stalls on take off
I believe the fuel filter needs to be replaced.
jim beam
Guest
Posts: n/a
when was the ignition system last serviced? different amounts of gas
need different spark strength at the plugs - if the ignition componentry
is getting weak, you could be getting weak spark at certain revs.
also check the engine computer for codes - you may have something like a
faulty throttle position sensor, but that's much less likely.
dspguy
Apr 7, 2019 03:00 PM
macbuddy
May 17, 2014 03:40 PM
DesignGuy
Jul 21, 2005 01:41 AM
Rocky
Jul 1, 2005 02:40 PM
Imminent Vengeance
May 4, 2005 04:44 PM
