how can I tell if 1.5L spark is weak?
Old Jun 29, 2005 | 09:30 PM
Rocky
Guest
Posts: n/a
I did a head gasket on a 1994 Civic 1.5L
now it won't start.
it cranks, battery has good charge.
TDC was set correctly.
inline spark tester has a slow, dim orange glow at night when I test each
cylinder.
New spark plugs are wet, gas odor, black soot on them.
Any suggestions on what to check next?
TeGGeR®
Guest
Posts: n/a
Re: how can I tell if 1.5L spark is weak?
"Rocky" <jcadellano.spam@optonline.net> wrote in
news:29Hwe.7496$2Z3.4511@fe10.lga:
> now it won't start.
> each cylinder.
Floor the gas pedal and leave it there. Crank until it starts.
That procedure shuts off the injectors to clear a flooded condition, which
it appears you've got.
TeGGeR®
www.tegger.com/hondafaq/
Old Jun 29, 2005 | 10:59 PM
Rocky
Guest
Posts: n/a
I already had tried that - how long should I let it crank? The car has 176k
miles on it.
I've already had to charge the battery once - the car was sitting for a few
weeks before I had time to put the head back on the motor. It started and
ran fine before I pulled the head off.
The head I put on was from a 1995 with 80k miles on it. The shop said it
passed the tank and pressure test and they planed the bottom.
"TeGGeR®" <tegger@tegger.c0m> wrote in message
news:Xns9684D71D9C637tegger@207.14.113.17...
>> now it won't start.
>> each cylinder.
> TeGGeR®
TeGGeR®
Guest
Posts: n/a
news:YKHwe.7501$2Z3.201@fe10.lga:
>> which it appears you've got.
Until it starts.
> The car has 176k miles on it.
> a few weeks before I had time to put the head back on the motor. It
> started and ran fine before I pulled the head off.
Leaky injector? Are ALL the plugs wet with gas, or just one?
Do you get a spark at the plugs?
TeGGeR®
Old Jun 30, 2005 | 12:43 AM
jim beam
Guest
Posts: n/a
> now it won't start.
> cylinder.
dumb question, but have you double checked the firing sequence?
Old Jun 30, 2005 | 08:55 AM
r2000swler@hotmail.com
Guest
Posts: n/a
Tripple check it!
I hate to admit it but I once got a tad mixed up and
spent an hour witht he smae syptoms before I noticed
that I had offest everything by one. It is easy to get mixed
up, even when you lable the cylinder, cap anb cables.
Even with a weak spark you ought to get some attempt
at starting. A weak spark can cuase major divibility issues.
Terry
Old Jul 1, 2005 | 02:40 PM
Rocky
Guest
Posts: n/a
The timing belt was on one tooth off.
I replaced the distributor, cap, rotor and wires - the car ran for 5 seconds
and died. I re-checked TDC & the cam position and found it was one tooth
off. Once I made that adj, it started instantly. Now the alternator is
seized, but that is easy to replace.
thanks for everyones ideas.
"Rocky" <jcadellano.spam@optonline.net> wrote in message
news:29Hwe.7496$2Z3.4511@fe10.lga...
> now it won't start.
> cylinder.
SilverEX15
Mar 1, 2017 04:56 PM
hqly
May 29, 2014 09:25 PM
Jun 3, 2005 01:06 AM
John
May 4, 2005 04:44 PM
Subhabrata Bhattacharyya
